Author Topic: Power Steering Mod???  (Read 1893 times)
February 11, 2015, 08:09:30 am
ftm1776
  • 149
« on: February 11, 2015, 08:09:30 am »
Low prioirity, but I like the idea of removing the power steering and going with a manual rack. I guess that there a lot of opinions as to whether that makes any sense, but that's not the issue here.
Although my Rabbit got along with one belt, no PS, I do like the redundancy of two belts driving the water pump. So here is the question:
Is it possible to get rid of MOST of the power steering gear and leave the pump/pulley in place, no lines hooked to it, in order to keep the second belt? Or substitute a shorter belt which would still need a movable pulley for removal and adjustment???
Is there just about no chance of one belt breaking if it is maintained and occasionally replaced???
If money was not the issue, I would have a manual rack substituted.
Any comments on this??????
Thomas, Original and sole owner since new:
1991 Jetta NA 1.6 diesel, Engine Code ME, 5 speed, AWY transmission, Hydraulic Lifters
293,000 miles
LOOKING FOR A GOOD VW DIESEL ENGINE BUILDER ON THE WEST COAST
Reply #1February 11, 2015, 08:24:58 am
RunninWild
  • 609
Re: Power Steering Mod???
« Reply #1 on: February 11, 2015, 08:24:58 am »
I'd imagine the pump would seize. The fluid is used for lubrication and cooling as well as driving the rack. I doubt it would last very long.
1 belt is fine, just check its condition every month or so and replace when necessary.
Reply #2February 11, 2015, 08:28:09 am
« Reply #2 on: February 11, 2015, 08:28:09 am »
There's very little chance of a belt failing that's properly maintained and not slipping.  If you've got a non-AC non-PS belt setup it takes no time to swap the belt either, your redundancy can easily be a belt and a couple wrenches stashed under the driver's seat.
