Author Topic: Convert NA pump w/ altitude correction to TD pump?  (Read 5926 times)
Reply #15January 19, 2015, 07:25:11 am
jmaddocks
  • 75
Re: Convert NA pump w/ altitude correction to TD pump?
« Reply #15 on: January 19, 2015, 07:25:11 am »
The fitting for the atmospheric side has a small filter to keep dust out of the aneroid.  I would not recommend leaving it just open.
Yeah, I installed a short piece of tubing that points downward but need to go back and add a filter.
Here's the fitting I used.  HTH
-Jason
'89 Jetta 1.6d HE200WG, ported solid lifter head, ARP studs, FMIC, 2.5" exhaust, lightened FW, ACT clutch
'79 Rabbit ABA swap, microsquirt
'91 Corrado 1.9L T3/T04e, ported 16v head, JE pistons, Scat rods, megasquirt, peloquin, E85, etc
Reply #16February 09, 2015, 07:09:50 am
TimpanogosSlim
  • 590
    Pretty dumb for a smart guy
« Reply #16 on: February 09, 2015, 07:09:50 am »
Fwiw, i finally asked giles about parts. He basically hinted that i should pay him to do the full tune up.
Which is what i figured he would do. Which is why i was looking for a non-giles supplier of parts.
.:Sent by pneumatic tubes
Reply #17February 09, 2015, 09:04:27 am
« Reply #17 on: February 09, 2015, 09:04:27 am »
Hey I think I have a 1.6TD parts pump, it has all the LDA parts in it still.  I'd be willing to part with the boost pin / spring / external fittings...
Reply #18February 09, 2015, 09:06:41 am
TimpanogosSlim
  • 590
« Reply #18 on: February 09, 2015, 09:06:41 am »
That could work.
