Model Specific Questions and Info
MK2 Golf/Jetta and Audi 5k
Strut oddness perhaps?
Topic: Strut oddness perhaps? (Read 7025 times)
December 24, 2014, 10:12:23 pm
jhax
December 24, 2014, 10:12:23 pm »
Hey kids, im in the process of re-clutching the ol' girl and I noticed something rather interesting. While the wheels are in the air the tops of the strut housings (upon which the black plastic caps sit) moves down roughly two inches to become "flush" with the strut housings. When the wheels are on the ground, the weight of the car pushes the rubber spring housing becomes flush with the bottom of the strust housing on the body. Is this normal? I can grab the top of the strut and move it within the housing a substantial amount while the wheel is in the air.
December 24, 2014, 11:05:48 pm
Re: Strut oddness perhaps?
December 24, 2014, 11:05:48 pm »
Yup, that's how VW suspension works. Weird eh?
December 25, 2014, 07:34:03 am
jhax
December 25, 2014, 07:34:03 am »
Very. Perhaps they designed it so a top mounted strut bar could be placed there with ease?
December 25, 2014, 09:17:32 am
December 25, 2014, 09:17:32 am »
I'm guessing they assumed the front end would never get airborne, what with the weight of the engine and all.
The rears, of course have rubber retaining bushings to handle the suspension drop or body lift.
December 27, 2014, 02:54:52 pm
December 27, 2014, 02:54:52 pm »
Yes, your struts are fixed to the body by nothing other than the force of gravity of the earth... though the caps fastened to the tops of the strut mounts limit their downward travel. The first time I discovered this I thought "really, VW, how cheap of you..." but that's how it is on the mk2 and up.
January 02, 2015, 02:47:20 pm
ftm1776
January 02, 2015, 02:47:20 pm »
Here's my thread on this weirdness........""shocking"" when first discovered !!!!!
I posted in the IDI section.
http://www.vwdiesel.net/forum/index.php/topic,34911.msg330934.html#msg330934
Thomas, Original and sole owner since new:
1991 Jetta NA 1.6 diesel, Engine Code ME, 5 speed, AWY transmission, Hydraulic Lifters
293,000 miles
LOOKING FOR A GOOD VW DIESEL ENGINE BUILDER ON THE WEST COAST
April 03, 2015, 04:04:08 am
smutts
ClackClackClackClackClack
April 03, 2015, 04:04:08 am »
The european mk2 golfs, if driven hard, pick up the inside rear wheels. So only use three wheels to go round corners. Perhaps the thinking of the fronts was, if the inside fronts picked up, it wouldn't matter as you would most likely be dead in the next second as you examined the scenery upside down and sideways at 100mph.
April 05, 2015, 07:00:55 am
air-cooled or diesel
April 05, 2015, 07:00:55 am »
it doesnt really bother anything; perhaps in the extreme, if the front wheels do become airborne the top caps keep suspension in order and the weight of the wheels and suspension can slam top of strut mount, shouldnt be a problem. all the weight is going down to the top rubber mounts below strut mount. its going to be really difficult to get the wheels airborne.
April 06, 2015, 08:18:29 pm
jhax
April 06, 2015, 08:18:29 pm »
So it turns out that my strut bushings were absolutely shot. I was trying to explain to the alignment guy that that's how they were. Then I got new ones, put it this way, with the old ones on, I could not rub my hand palm down flat on the tire without scraping the back of my hand on the wheel well. Now I can!
April 06, 2015, 08:21:53 pm
April 06, 2015, 08:21:53 pm »
i replace mine when i rebuild suspension; like every 6yrs.about $20 a side
