Author Topic: cat converter  (Read 2344 times)
March 28, 2006, 02:24:24 am
grannat
  • 10
cat converter
« on: March 28, 2006, 02:24:24 am »
I spent my last rotation off work under my car installing a new stock downpipe.  I removed my catalytic converter to make this easier and took a look inside. I should have guessed that a car with 308,000 km would have a plugged cat but holy cow, it was full!  Needless to say I cut the flange off the old DP and wlelded a straight pipe to it. So now with no cat it is running a lot better, revs faster and higher, turbo spool up is faster, and highway cruising is much improved!  I don't know if fuel consumption is lower, I will know in a couple weeks when I finnish this tank, I assume it will be better. Currently I am getting 7650-775 on a tank (94 jetta td).
Any down sides to removal of cat? Besides e-test and T.C.
Thanks
Reply #1March 28, 2006, 04:08:12 am
cat converter
« Reply #1 on: March 28, 2006, 04:08:12 am »
how is the noise from the straight pipe? vibrations?
Reply #2March 28, 2006, 10:47:22 am
grannat
  • 10
cat converter
« Reply #2 on: March 28, 2006, 10:47:22 am »
Its actually quieter, there was a hole in my downpipe and now I have a new used one in there. There is no vibration or excess noise, just perforance improvments in all aspects.
