For Sale/Looking For
Parts for Sale/Wanted
WTB Coolant outlet neck 1.6TD
Topic: WTB Coolant outlet neck 1.6TD (Read 6864 times)
November 15, 2014, 06:39:45 pm
mcpook
November 15, 2014, 06:39:45 pm »
Wanted to buy a coolant outlet neck for a 1.6 turbo diesel. VW part # 068 121 133. The one that I have has extensive corrosion on the neck as seen in the pics. Thanks.
1982 Rabbit Pickup 1.6 TD
1996 Passat B4V TDI
November 19, 2014, 11:07:12 am
DogDiesel
Re: WTB Coolant outlet neck 1.6TD
November 19, 2014, 11:07:12 am »
http://www.vwdiesel.net/forum/index.php?topic=27418.0
http://www.amazon.com/Altrom-068121133AF-Auto-Part/dp/images/B002E2VEDE
http://www.autoparts007.com/oem_068-121-133-AE/Detail_23955_Thermostat-Housing.html
Shipping for used part will be as much or more than for new. You will need O-ring to match.
Found the part out there.
Wayne
Last Edit: November 19, 2014, 11:11:55 am by DogDiesel
November 19, 2014, 01:44:04 pm
November 19, 2014, 01:44:04 pm »
The ones you've linked to aren't correct for a Mk1. The Mk1 neck is metal and has threaded screw-in single pin temperature sensors. The Mk2+ neck is plastic and has clip-in 2 pin temperature sensors. To swap a plastic one for a metal one you also need to swap the temperature sensors and change the connectors over to a 2-pin one, then add a ground connection. By the time you buy the neck, the temp sensor(s), the associated sealing rings, the sensor clips and the wiring harness clips you'll be in around $100.
November 20, 2014, 12:10:21 pm
DogDiesel
November 20, 2014, 12:10:21 pm »
Bryn,
Respond where to buy the aluminum ones. MK1 Warehouse does not stock them. No one has responded with a used aluminum one.
Wayne
November 20, 2014, 04:53:12 pm
EcoTX
November 20, 2014, 04:53:12 pm »
I've responded through a PM to him, I have quite a few of these aluminum coolant flanges in a box.
November 24, 2014, 06:29:29 am
November 24, 2014, 06:29:29 am »
http://www.vwdiesel.net/forum/index.php/topic,35354.0.html
November 24, 2014, 11:29:55 am
mcpook
November 24, 2014, 11:29:55 am »
Quote from: RabbitJockey on November 24, 2014, 06:29:29 am
Looks to lack the second threaded sensor port. Similar to what is pictured here:
http://www.ebay.com/itm/361032074845?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649
or here:
http://www.ebay.com/itm/281128711980?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649
Both are close...but not quite what I'm looking for.
1996 Passat B4V TDI
November 24, 2014, 05:10:28 pm
RunninWild
November 24, 2014, 05:10:28 pm »
I may have one in my parts pile, I'll have a look tomorrow and send you a pm if I do. Curious what they are worth?
November 26, 2014, 09:44:45 pm
November 26, 2014, 09:44:45 pm »
I'll check the bucket.
December 04, 2014, 02:58:04 pm
mcpook
December 04, 2014, 02:58:04 pm »
Still looking. EcoTX didn't have the one I need. Through some research, I think it's part number 068 121 133R, which is NLA. Not sure what they are worth, since I haven't seen the exact one available. The single threaded port style 068 121 133M go for $15-20.
Thanks.
1996 Passat B4V TDI
December 04, 2014, 07:19:50 pm
December 04, 2014, 07:19:50 pm »
i've never seen one like yours before, does the port on the side of the head for the heater core have no sensors in it? you're probably better off just getting a set to the more normal setup with the sensors on the side of the head. or if you can find someone that tigs aluminum that'd be much quicker than continuing your search.
Reply #11
May 31, 2015, 09:02:04 pm
maloosheck
Newbie
Reply #11 on:
May 31, 2015, 09:02:04 pm »
I am looking for the same one. The actual part number appears to be 068121133R. It is alloy made, has two threaded sensor ports and two hose connectors.
18 cylinders of torque
For sale bucket
4M
otion Swap Project
Reply #12
June 25, 2016, 12:31:21 pm
filmshoot
Newbie
Reply #12 on:
June 25, 2016, 12:31:21 pm »
Hi I'm looking for a 1.6td aluminum flange that will mount on my afn engine. I want to replace the plastic ccv tubing. I will weld a barbed end onto the 1.6td flange.
Inscribed with just two thumbs...
