Author Topic: Headlight adjuster screw is stripped.  (Read 6470 times)
November 11, 2014, 07:41:31 am
jaed_43725
« on: November 11, 2014, 07:41:31 am »
I ended up taking the whole headlight out. Is there some tip or trick that someone here has used that I can put in a different more available adjustment setup? The dealership can no longer get them and what remains is insanely expensive. Any help is appreciated. Thanks.
Reply #1November 11, 2014, 04:00:26 pm
jaed_43725
Re: Headlight adjuster screw is stripped.
« Reply #1 on: November 11, 2014, 04:00:26 pm »
I ended up taking the dremel and making the phillips into flat head screws. And I ordered a new kit of all 3 screws with bushings off of EBay, but they have to come from the UK.
Reply #2November 30, 2014, 09:30:37 pm
  • 2932
« Reply #2 on: November 30, 2014, 09:30:37 pm »
I ground down part of a nut and it fit right onto the stripped plastic piece.
 I also made a couple all metal adjuster pieces when a plastic piece broke.
Reply #3December 02, 2014, 11:11:45 am
« Reply #3 on: December 02, 2014, 11:11:45 am »
That's been my experience too, the 20 year old plastic strips and there is no aftermarket item that fits our particular cars (if you have a mk2) and VW does not care to provide a replacement and the only ones I've found are used or on ebay from europe.
Reply #4February 20, 2015, 12:18:58 pm
  • 2932
« Reply #4 on: February 20, 2015, 12:18:58 pm »
 I made a few metal headlight adjusters for the MK1:
Also ground down a nut so it would fit down in the right area, when the threads would no longer grip the plastic:
