Author Topic: Temp light coming on intermittently, mk2 jetta  (Read 9415 times)
October 22, 2014, 07:11:16 pm
Diesel_Zuk
  • 182
« on: October 22, 2014, 07:11:16 pm »
1991 ecodiesel, light has been coming on immediately after starting in the morning. Ebgine is still cold. I've checked the antifreeze level, it's good. I shut it off and restart, and it goes away. 30 minutes later, comes on again, shut it off, restart, and it doesn't come back on for rest of my commute. I'm guessing it's nothing major, because it's been happening for about a month now, mileage is still 40 mpg, coolant level still good. Any ideas where to start?
Reply #1October 22, 2014, 08:57:53 pm
Re: Temp light coming on intermittently, mk2 jetta
« Reply #1 on: October 22, 2014, 08:57:53 pm »
Is it on steady or flashing?
Reply #2October 23, 2014, 07:58:43 am
Diesel_Zuk
  • 182
« Reply #2 on: October 23, 2014, 07:58:43 am »
Flashing. I unplugged it and plugged both sensors coming off the head, then treconnecter, and it didn't happen for about a week, but it's now doing it quite often.
Reply #3October 23, 2014, 01:22:53 pm
Patrick
  • 1034
« Reply #3 on: October 23, 2014, 01:22:53 pm »
If it's flashing it's probably telling you that there is water in the seperator ahead of the back wheel.
Reply #4October 23, 2014, 08:57:41 pm
Diesel_Zuk
  • 182
« Reply #4 on: October 23, 2014, 08:57:41 pm »
What's that mean? I seriously don't know.
Reply #5October 24, 2014, 08:10:06 am
« Reply #5 on: October 24, 2014, 08:10:06 am »
The water separator will flash the glow plug light, not the temp light.
Either you've got a wiring issue somewhere, the probes in the coolant reservoir are bad or your cluster is having issues. Start with the wiring, I had the same problem with mine. In my case the solution was to re-pin the connector at the coolant ball, it was not making a good connection.
Reply #6October 25, 2014, 04:10:19 am
Patrick
  • 1034
« Reply #6 on: October 25, 2014, 04:10:19 am »
I stand corrected. Mine hasn't done it in a long time.....
Reply #7October 27, 2014, 04:22:23 am
air-cooled or diesel
« Reply #7 on: October 27, 2014, 04:22:23 am »
check,clean up contacts. the radiator fan switch is at the bottom of the radiator drivers side, check, clean up. i found when this was happening to me , years ago, it was the reservoir sensor, i ended up getting a new reservoir. i use electronic spray for contacts. could be a just low water level? or a restriction , check reservoir return flow, dont let it boil over while checking.
Reply #8October 27, 2014, 03:15:30 pm
Diesel_Zuk
  • 182
« Reply #8 on: October 27, 2014, 03:15:30 pm »
I don't think it's low, but I guess it is possible. I haven't checked it in a little while.
Reply #9October 28, 2014, 12:51:49 pm
  • 2932
« Reply #9 on: October 28, 2014, 12:51:49 pm »
Bad ground on the resevoir sensor?
Reply #10October 28, 2014, 07:02:06 pm
Diesel_Zuk
  • 182
« Reply #10 on: October 28, 2014, 07:02:06 pm »
Just checked coolant level. My overflow tank is so dirty I cannot easily see a line of where the level is, but I think it looks full. It seems odd that if it was just low, that it would only come on at times, and not always on.
Reply #11October 28, 2014, 08:21:39 pm
« Reply #11 on: October 28, 2014, 08:21:39 pm »
Actually that's not surprising at all. Once it detects a low level it latches on until the car is shut off. A quick turn, steep hill or heavy braking or acceleration can slosh the coolant around enough to trigger it if the level is just a bit low.
Also, if your coolant bottle is nasty then there is a good chance the probes are filthy too, making a good connection difficult.
Reply #12October 31, 2014, 09:54:11 am
Diesel_Zuk
  • 182
« Reply #12 on: October 31, 2014, 09:54:11 am »
I unplugged the things again on the head, and noticed they felt wet, not sure what from, but I left them to dry, and light hasn't come on since. Not sure if it was just low or what.
Reply #13October 31, 2014, 03:21:08 pm
« Reply #13 on: October 31, 2014, 03:21:08 pm »
hit contacts with electronic spray and let dry, may help.
Reply #14October 31, 2014, 11:10:42 pm
TimpanogosSlim
  • 590
    Pretty dumb for a smart guy
« Reply #14 on: October 31, 2014, 11:10:42 pm »
Yup. CAIG De-OxIt DN5 spray. amazing what it'll fix.
