Author Topic: Timing belt idler pulley  (Read 2062 times)
March 26, 2006, 04:10:11 am
Powjetta
  • 152
    San Diego CA
« on: March 26, 2006, 04:10:11 am »
I'm new here as I just bought a '86 2 door jetta.  The odometer was broke so I am replacing the timing belt.  It looks pretty good but the back had some lines on it like it was sliding on the idler pulley and when I checked the pulley it seemed very tight.  I can turn it with the end wrench on it and sometimes after I get it started I can turn it by hand but not always.  Shouldn't this turn a little easier?  Is there a bearing in behind it?  My book makes no mention of this pulley that I see, the larger diameter pulley between the pump and crank.  I did a search but couldn't find any reference to this pulley.  Let me know if anyone has ever seen this, thanks.
'86 jetta 2 dr Turbo diesel K24 - sold
'94 GMC 6.56TD - sold
Reply #1March 26, 2006, 07:24:09 am
wyldman
  • 403
« Reply #1 on: March 26, 2006, 07:24:09 am »
That's the intermediate shaft.It turns the oil pump and vacuum pump.It may be stiff,as it has to work to turn everything else.You could also have a bad intermediate shaft bearing.
You could pop the vacuum pump off and see if it frees up.
(416)565-7282
