Author Topic: Convert odometer from km to miles?  (Read 4760 times)
March 24, 2006, 06:32:27 pm
MadCityMike
  • 21
« on: March 24, 2006, 06:32:27 pm »
Just picked up a Canadian 1.9TD 94 Jetta.    I picked up a US gas dash cluster so that I can convert the face of the speedometer to mph instead of km/h as well as the temp to degrees instead of celcius.   Since it's a gas cluster I can't just swap in the whole unit.    Is there any way to convert the lcd odometer to miles instead of km?    By the way, does anyone know of any good links to WVO conversions specifically for this engine?
Mike
Mike
94 Jetta, 1.9l TD AAZ code
Reply #1March 25, 2006, 06:36:53 pm
wyldman
  • 403
« Reply #1 on: March 25, 2006, 06:36:53 pm »
I don't recall any way to switch from KM to miles without reprograming the cluster.Some other makes allow you to switch the display back and forth.
On some VW OBDII cars,you can access it via the CANbus,and change it.On the older cars you need a flash programmer to change the EPPROM in the cluster.
(416)565-7282
