tiny piece of metal dropped in injector hole - pull head or not on low budget
Pages:
Topic: tiny piece of metal dropped in injector hole - pull head or not on low budget (Read 14191 times)
Reply #15
September 06, 2014, 11:18:14 pm
Dakotakid
Re: tiny piece of metal dropped in injector hole - pull head or not on low budget
Reply #15 on:
September 06, 2014, 11:18:14 pm »
How did this ever end? Inquiring minds want ter kno'!
The problem with opening up an original '87 engine is that it is going to look like hell! More than likely complete with a ridge you can break your leg on. I HATE opening up something like this for that reason. Then what....put it back together as is?
Last Edit: September 06, 2014, 11:21:45 pm by Dakotakid
Reply #16
September 07, 2014, 09:55:42 pm
shorttimer
Reply #16 on:
September 07, 2014, 09:55:42 pm »
One thing to consider. Not all tools are magnetic. Some picks are made of stainless. And some stainless IS magnetic and some are not. My first thing to try, before going further with the magnet approach, is to determine that the part that broke off is magnetic. I hope it is & good luck.
Reply #17
September 08, 2014, 01:40:46 am
Toby
Reply #17 on:
September 08, 2014, 01:40:46 am »
You guys worry to much. Roll the motor over by hand and see if it binds anywhere. If not, run it. A chunk of steel that small is unlikely to do much more than scar up the top of a piston a bit before it goes out the exhaust port. If this were a known good motor that I wanted to get another 200K miles on in a nice car, then It might be better to pull the head. But this is an old DD. Put the GP and injector back in and run it.
FWIW about half of the IDIs that I have been into had some kind of scaring on at least one piston. Did not seem to have any effect.
N.B. I am not saying this is "best practice". Just that it is unlikely to hurt an old motor enough that you will notice.
The chunk of steel is so tiny that all of the things you guys have been catastrophising about are very, very unlikely.
Reply #18
September 09, 2014, 07:36:49 am
Dakotakid
Reply #18 on:
September 09, 2014, 07:36:49 am »
Exactly! (applause)
Reply #19
September 09, 2014, 07:45:53 am
Reply #19 on:
September 09, 2014, 07:45:53 am »
I wonder what it will do if it hits the turbine.
Reply #20
September 09, 2014, 03:29:22 pm
Toby
Reply #20 on:
September 09, 2014, 03:29:22 pm »
Who says it has a turbo? Did I miss something?
Even if it is a turbo, it is very unlikely that it would damage anything. We are discussing TINY chunk of steel. None the less, if it were a turbo, and mine, I would just let it idle for a while to blow it out and then drive it gently for a mile or so.
Reply #21
September 09, 2014, 08:13:21 pm
Reply #21 on:
September 09, 2014, 08:13:21 pm »
He says so in the initial post.
Quote from: purvisgs on August 30, 2014, 10:29:12 am
This is an 87 hydraulic 1.6td.
Reply #22
September 09, 2014, 08:33:41 pm
Dakotakid
Reply #22 on:
September 09, 2014, 08:33:41 pm »
I gots $10 that sez it won't........
Pages:
