Author Topic: 1Z vs AHU oil filter housing  (Read 6074 times)
August 23, 2014, 02:47:14 pm
Smoker
  • 255
« on: August 23, 2014, 02:47:14 pm »
I'm putting my ahu back together with a 1Z block that I had sitting in the corner.  My issue is the banjo bolt is not the same size as the threads in the filter housing on the 1Z block... has anyone run into this before?  Just drill and tap the housing to the right size?  I think I scrapped the old ahu block with the housing still on it.  ::)
Reply #1August 23, 2014, 03:17:57 pm
Diesel_Zuk
  • 182
Re: 1Z vs AHU oil filter housing
« Reply #1 on: August 23, 2014, 03:17:57 pm »
I have an ahu housing I don't need because I am using an angled one. It's yours if you want it. You will need to use the nipple off yours though, the thing that goes through the oil cooler and the filter screws on to. I had a remote filter kit mounted on it so I removed it and put a shorter one in it's place. Let me know if you want it, if you want it, I can send it if you just cover shipping.
Reply #2August 23, 2014, 03:34:28 pm
Smoker
  • 255
« Reply #2 on: August 23, 2014, 03:34:28 pm »
Yes please!  Where are you located?  Just trying to figure out how soon it could be here... I'm trying to meet a deadline.
Reply #3August 24, 2014, 08:42:00 pm
Diesel_Zuk
  • 182
« Reply #3 on: August 24, 2014, 08:42:00 pm »
I'm located in Lincoln Nebraska. I can get it shipped out to ASAP. I sent a PM your way.
