Author Topic: WTB 1.9TD AAZ with Garrett T2 turbo wanted  (Read 4596 times)
August 11, 2014, 09:00:23 pm
rotaecho
  • 33
« on: August 11, 2014, 09:00:23 pm »
I am seeking a functioning 1.9TD AAZ with a Garrett T2 turbo ideally from a Passat.
I am located in Los Angeles, CA.
-Will
1982 Westfalia 1.6na diesel aka Betsy Bertha The Tortoise
Reply #1August 11, 2014, 09:29:16 pm
GEE-BEE
  • 1604
Re: WTB 1.9TD AAZ with Garrett T2 turbo wanted
« Reply #1 on: August 11, 2014, 09:29:16 pm »
Try Thomas at Quality german Auto in Montclair
Why a AAZ ?
T2/T3 will be hard to find
k14/k24
these are early models
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2December 29, 2014, 04:23:17 pm
rotaecho
  • 33
« Reply #2 on: December 29, 2014, 04:23:17 pm »
GeeBee,
This is an old post when I was thinking of going the TD route on my 82 Vanagon, but I'm leaning more towards a 1Y (1.9na) engine or a ADG 1.9 engine.
I'm more familiar with my 1.6 so the learning curve is easier. From what I read, if you can't support your conversion, then might as well not convert. With that advice, I'm going a lateral move with the 1.9na just a bit more hp.
Now, I'm thinking about a possible AAZ and stripping the turbo and when I'm more comfortable put it back on.
Thomas at Quality german Auto, is high on my list; however, I'm also open to other options.
I'm at least a year or two away. I need to get other supporting work done (radiator upgrade, wheel upgrade, new springs, lift kit, exhaust/intake, and a giles pump.) before I attack the 1.9na conversion.
Decisions decisions :)
quote author=GEE-BEE link=topic=35032.msg332082#msg332082 date=1407817756]
Why a AAZ ?
k14/k24
[/quote]
-Will
Reply #3January 04, 2015, 09:41:46 pm
RunninWild
  • 609
« Reply #3 on: January 04, 2015, 09:41:46 pm »
ive got a aaz head if you want? Was pulled from a running engine, looks to be in decent condition.
