Author Topic: Injection pump doesn't spray fuel  (Read 5745 times)
August 11, 2014, 08:12:17 pm
Diesel_Zuk
  • 182
« on: August 11, 2014, 08:12:17 pm »
I bought this pump from 8v-of-fury!, and got absolutely screwed. I knew ahead of the purchase he was moving, and so it would be hard to get ahold of him. Now, he can't give me my money back because he doesn't have enough to pay me back. The problem is this pump will not spray fuel. If I loosen up the delivery valves in the head it will, otherwise it just doesn't seem to build pressure. Is there anybody out there that can help me out on this? I'm a college student that was without a car for a couple months, and I can't afford to take a $400 loss.
Reply #1August 11, 2014, 10:28:47 pm
Re: Injection pump doesn't spray fuel
« Reply #1 on: August 11, 2014, 10:28:47 pm »
Are you looking for us to contribute with a small cash donation or fix the pump to make it work?  What is it you would have us do here to help?  Remind the reader here, what type of IP is it exactly.  Keeps us from chasing a thread down.
Installment plan for 8V might be an option.
Reply #2August 12, 2014, 06:03:00 pm
Diesel_Zuk
  • 182
« Reply #2 on: August 12, 2014, 06:03:00 pm »
That would be nice. The pump is a 1.6 turbo pump, with governor mod.
Reply #3August 12, 2014, 06:54:24 pm
« Reply #3 on: August 12, 2014, 06:54:24 pm »
I know you bought this to stop a problem of leaking if I remember right.  Then you fixed your old pump to get you running again.  Do you have the ability to tear into the pump and see if something is whacko with it?  Or would you not even know how to tear into a pump and get it back to running condition.
Reply #4August 12, 2014, 07:28:05 pm
Diesel_Zuk
  • 182
« Reply #4 on: August 12, 2014, 07:28:05 pm »
I probably could, but I don't want to risk it, I have never opened one before. What I sealed on my old pump was simple, I just put a new o ring on the cold start lever.
Reply #5August 12, 2014, 10:21:11 pm
« Reply #5 on: August 12, 2014, 10:21:11 pm »
Oh, that is kid stuff then.  I thought you did the front seal or the back one with the slip trick.  In that case leave as is, might be an issue with an exchange if that is possible.
Reply #6August 21, 2014, 09:43:03 pm
Diesel_Zuk
  • 182
« Reply #6 on: August 21, 2014, 09:43:03 pm »
Well I thought I fixed the leak, it is once again leaking from the cold start lever  >:(
Reply #7August 22, 2014, 10:16:40 am
« Reply #7 on: August 22, 2014, 10:16:40 am »
From the lever or from the cap?  Big O or little O rings needed
Reply #8August 22, 2014, 02:59:04 pm
Diesel_Zuk
  • 182
« Reply #8 on: August 22, 2014, 02:59:04 pm »
I did both the o ring on the shaft, and the cap. Brand new from a reseal kit.
Reply #9September 07, 2014, 10:16:19 pm
Diesel_Zuk
  • 182
« Reply #9 on: September 07, 2014, 10:16:19 pm »
Bump. Any ideas? Anybody wanna tear into it for me? Lol
