Author Topic: F.S. AAZ Complete Cylinder Head  (Read 3804 times)
July 27, 2014, 02:41:50 pm
ein bora
  • 377
« on: July 27, 2014, 02:41:50 pm »
This is basically a brand new cylinder head as it has only about 20 hours of run time on it. I had a G60 valve cover on it but the bolts easily remove if you wanted to go back to a oem valve cover. The ports have been polished and gasket matched. Absolutely perfect. Asking $800.00 + shipping.
Please email me with questions or interest at - [email protected]
Thanks.
If you can't take advice - then you can't be helped!
Reply #1July 27, 2014, 03:45:40 pm
GEE-BEE
  • 1604
Re: F.S. AAZ Complete Cylinder Head
« Reply #1 on: July 27, 2014, 03:45:40 pm »
German mfg is top notch, iam trying to find a ahu head, new from Germany
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
