Author Topic: WTB: lower half of return line  (Read 5241 times)
July 15, 2014, 07:28:28 pm
Rising
  • 385
« on: July 15, 2014, 07:28:28 pm »
Hoping somebody has a busted one so I don't have to cut up a good one. But I'll take a good one. I just need to be able to connect to a stock mkii oil pan fitting and extend it to build a vnt-15 return line.
Thanks!
'84 Rabbit Diesel- 1.6D Stock
Reply #1July 20, 2014, 05:50:41 pm
Rising
  • 385
Re:
« Reply #1 on: July 20, 2014, 05:50:41 pm »
Anybody know a source for these? Hansautoparts seems to be the only place I can find these online... That's prothe right? I was just going to cut it up to make a custom joint. Basically just need that fitting... Would that be a bad idea?
Reply #2July 21, 2014, 04:21:16 pm
  • 2932
Re: WTB: lower half of return line
« Reply #2 on: July 21, 2014, 04:21:16 pm »
Just a straight piece of pipe with a compression fitting isn't it?
Reply #3July 21, 2014, 07:36:55 pm
Rising
  • 385
Re: Re: WTB: lower half of return line
« Reply #3 on: July 21, 2014, 07:36:55 pm »
Mine looks like this.. I'm trying to get something to thread onto that piece however there is no online documentation that I can find of thread type size etc. Theman has commented that he found a jic fitting that seemed close but he wasn't sure which one etc.
Nothing at any local store is even close to that size. So I'm considering just buying that cheap oil line and hacking it up just for that end. At 35 with shipping I would hate to cut up an OEM line...
http://www.hansautoparts.com/068145736AOilReturnLine.aspx
Reply #4July 21, 2014, 07:47:22 pm
« Reply #4 on: July 21, 2014, 07:47:22 pm »
I found what it was a while ago, but again I do not remember. I know it is metric and I am thinking it should be fairly easy to find. I will not say for sure, but I was thinking it was M20-1.5 thread. Measure across it and if you have a thread pitch gauge see if you can figure it out.
Reply #5July 22, 2014, 11:53:52 am
Rising
  • 385
Re:
« Reply #5 on: July 22, 2014, 11:53:52 am »
I came up with 22mm.. So m22x1.5 compression fitting is what I need?. I don't have a thread gauge around..
Where do you even find metric compression fittings that big...
Reply #6July 22, 2014, 04:23:03 pm
