Author Topic: WTB: TD Intake Elbow & Charge Hose  (Read 5737 times)
July 13, 2014, 11:40:11 am
CODE4LS1
  • 73
« on: July 13, 2014, 11:40:11 am »
I can't source this part anywhere, so I thought I might try here.
I am looking for the aluminum intake elbow from a factory 1.6TD that bolts to the intake manifold.  I need the one that points to the passenger side.  I would also like to find the rubber charge hose connecting the above mentioned elbow to the turbo.
Let me know what you got, I have cash in hand/Paypal ready.
Thx!
I found a 1.6TD complete engine, but the PO fashioned a homemade elbow/charge hose made of plumbing fittings.  I would much rather go with factory parts.
Reply #1July 13, 2014, 01:45:30 pm
GEE-BEE
  • 1604
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2July 13, 2014, 01:48:52 pm
GEE-BEE
  • 1604
Giles Pump OHC
MK1 JETTA DASH
Reply #3July 13, 2014, 02:17:15 pm
bryanb
  • 25
Re: WTB: TD Intake Elbow & Charge Hose
« Reply #3 on: July 13, 2014, 02:17:15 pm »
The elbow on the intake that bolts on can face either direction can't it?
Don't be retarded a glow plug is nothing like a spark plug
Reply #4July 13, 2014, 03:34:51 pm
« Reply #4 on: July 13, 2014, 03:34:51 pm »
No, there's a left hand orientation and a right hand orientation. I think it will physically flip but won't point in the direction to line up with the elbow coupler from the turbo, it winds up offset about maybe 30 degrees. The normal one for TD Jetta/Golf/Rabbit is to the passenger side. The other kind came on... GTDs? Quantums? The nipple for the boost enrichment valve would also be on the other side, which isn't a big deal. The elbow coupler is available in a silicone aftermarket version as you see above and it works well.
Reply #5July 13, 2014, 03:53:33 pm
bryanb
  • 25
« Reply #5 on: July 13, 2014, 03:53:33 pm »
I didn't want to hijack but I was just wondering if I can flip mine around when I start to do piping for my inter cooler
Reply #6July 13, 2014, 10:50:33 pm
GEE-BEE
  • 1604
« Reply #6 on: July 13, 2014, 10:50:33 pm »
Easier to get a pd150 and race pipe as your angle is off
GB
I have a extra pd150 rh facing
Giles Pump OHC
MK1 JETTA DASH
Reply #7July 13, 2014, 11:26:39 pm
« Reply #7 on: July 13, 2014, 11:26:39 pm »
You can do it but it will face somewhat towards the firewall. Do what he said, change the manifold, there are options available that will allow you to have a much better angle of approach and a better manifold design as well with no hard 90 degree turns that the stock setup has.
Reply #8July 20, 2014, 09:23:29 pm
CODE4LS1
  • 73
« Reply #8 on: July 20, 2014, 09:23:29 pm »
GB
So the PD150 has the same shape ports as the 1.6??  If so, how much?
Reply #9July 20, 2014, 11:07:07 pm
TimpanogosSlim
  • 590
    Pretty dumb for a smart guy
« Reply #9 on: July 20, 2014, 11:07:07 pm »
GB
No, PD130 and PD150 (mirror image of each other) have D ports like all other modern vw diesels.
But they bolt up and seal anyway.
Reply #10July 23, 2014, 06:07:33 am
DJTC
  • 22
« Reply #10 on: July 23, 2014, 06:07:33 am »
I  have the elbow. check your inbox
