Author Topic: how long before mk1 cluster clock drains down a battery?  (Read 5981 times)
July 03, 2014, 03:57:05 pm
damac
  • 531
« on: July 03, 2014, 03:57:05 pm »
My 82 truck has been sitting still for a couple months since I last drove it.  It has cluster with ticking clock which was still working when I walked past, but not enough juice to crank much.  Curious if that might be normal.
1985 turbo diesel jetta
Reply #1July 03, 2014, 04:51:04 pm
Re: how long before mk1 cluster clock drains down a battery?
« Reply #1 on: July 03, 2014, 04:51:04 pm »
I think pretty much any car has enough parasitic drains to discharge a battery after a few months... disconnect the battery.
Reply #2July 03, 2014, 10:30:03 pm
Renax
  • 90
Re:
« Reply #2 on: July 03, 2014, 10:30:03 pm »
The solution is without doubt to drive it every day, or at least once a week.
I always make shure my cars are started and run for 20-30 minutes every week. Its not good for a car to be standing around...
I know one 83 model that has been sitting for at least a year and a half, clock still ticking... a tiny button battery is enough to have a clock going for a long time, a car battery has a lot more power than that, i bet it would discharge just as fast not connected...
Sent from my cheapchinaphone using Tapatalk
-89 Caravelle Coach 1.6TD (too be holset powered) Daily driver
-80 Golf 1.6D
Reply #3July 04, 2014, 04:33:57 pm
ToddA1
  • 434
« Reply #3 on: July 04, 2014, 04:33:57 pm »
My '81 truck sits for months, and I've never had an issue with the battery. My battery is larger than stock, though.  Other than the clock, I can't see anything in this old thing that would have parasitic draw.
I've recently bought one of those solar cell trickle chargers.
-Todd
Reply #4July 20, 2014, 11:46:42 am
iamdieselnutmechanic
  • 53
« Reply #4 on: July 20, 2014, 11:46:42 am »
Solar trickle chargers! A great idea for anything with a battery that sits.. I wish all the boats at the marina i work at had them.. Do you know how many people let their boat sit for 3 months and expect it to start and get them going like nothing?? idiots. Carbs dry and the batteries already weak.. means no start!
I would either get a solar charger, or disconnect the battery damac.
Also, it is better to sit than to be driven a for a few minutes. If they do not reach super hot oil temps you're just causing more issues with adding water to the crankcase.
Hey there, how you doin?
Reply #5August 16, 2014, 08:06:23 am
  • 1739
« Reply #5 on: August 16, 2014, 08:06:23 am »
My father's 84 gasser had the same battery in it for 10 years. drove maybe once a week, sometimes less.Wasn't plugged in during winter, never had the battery run down. If I remember, the analog clock should pull only 10 mA, not enough to drain a battery over a few weeks
Reply #6August 17, 2014, 01:32:27 pm
mtrans
  • 308
« Reply #6 on: August 17, 2014, 01:32:27 pm »
the analog clock should pull only 10 mA?
0.01*24 hour*30 day=7.2 Ah in winter it`s 50% more.
For 60 Ah battery you losse ~ 12%
Analog one,with el motor "I think" use up to 100 mA = 72 Ah
Radio + alarm from 0.1-0.2 Ampere per hour-tested.
I`ll improve my English
Reply #7August 18, 2014, 08:30:58 am
  • 1739
« Reply #7 on: August 18, 2014, 08:30:58 am »
Whatever. The last time I checked one was probably 25 years ago. My point was that with just the clock pulling current, it will take a while to drain the battery. I'm speaking from actual tests and personal experience. Details don't matter,only the results. 30mA is the limit as to what will kill a battery within a day or two
