Author Topic: Help: Leaking coolant - only when engine is cool - from behind oil pan .......  (Read 8020 times)
June 30, 2014, 12:31:02 pm
ReubenG
  • 46
81 diesel 1.6 ; recently replaced water pump, t-stat, radiator, and hoses. Drips coolant from behind oil pan, seemingly only when the engine is cool... I can't tell where it's coming from, but it definitely doesn't appear to be any of the hoses, or the radiator, or the water pump  ???
Reply #1June 30, 2014, 01:42:38 pm
A freeze plug would be my first guess...  There's 3 in the back of the block below the exhaust manifold.
Reply #2June 30, 2014, 02:09:57 pm
When you did the water pump did you replace the housing or just the pump. If you did the housing I could see it leaking from the o ring to the block and running around the block to the back...if it wasn't leaking before you did all the work.
Reply #3July 01, 2014, 11:17:21 am
ReubenG
  • 46
I never touched the freeze plugs....would they begin to leak for some reason after performing this maintenance? -- as for the pump, yes I replaced the entire housing too, with new o-ring, but it doesn't appear to be leaking from there. I'll take a closer look, but I think that's ok.
Reply #4July 01, 2014, 12:04:20 pm
Sometimes things have been happening for a while but until you start checking things over after working on them you don't notice.
Freeze plugs for instance can be weeping for a while and then once you flush the block and knock out the scale and rust that was sealing them, a small weep becomes more significant.
Easy enough to check either way. If coolant is coming from the back of the engine there are only a very few possible sources.
Reply #5July 23, 2014, 01:50:44 pm
smutts
  • 720
    ClackClackClackClackClack
Dying head gasket is also a possibility, drove me mad trying to find mysterious leak behind the block (no coolant pressurisation), until the thing blew properly 9 months later. ;D
Reply #6July 24, 2014, 01:13:17 pm
ReubenG
  • 46
Yes, it's definitely the freeze plug(s) --- One of them has a rubberish extension coming off it and coolant is pouring out of there. What is this? Also, the block heater is there, and possibly leaking a bit. Tips?
Reply #7July 24, 2014, 01:15:34 pm
Remove and repair.  two tips no charge
Reply #8July 24, 2014, 01:32:58 pm
Re:
« Reply #8 on: July 24, 2014, 01:32:58 pm »
Yup. Knock em out, hammer in new ones, done. If you don't use / need the block heater you can replace it with a normal freeze plug.
Reply #9July 24, 2014, 02:19:20 pm
ReubenG
  • 46
...I saw a youtube video where a guy used part of a channel lock pliers to wedge them out, see here: https://www.youtube.com/watch?v=MlK321GS94U
thoughts?
Reply #10July 25, 2014, 09:39:55 am
ReubenG
  • 46
can I replace the core heater plug with a regular freeze plug?  any DIYs on removing the plugs? THANKS
Reply #11July 25, 2014, 11:26:02 am
Re:
« Reply #11 on: July 25, 2014, 11:26:02 am »
Yes, absolutely.
Reply #12August 04, 2014, 09:41:36 am
ReubenG
  • 46
Lucky for me it was only the core heater that was leaking and not any of the freeze plugs. Took 5 minutes to remove the old heater plug and put in a new one. ... then refill cooling system of course. Thanks!
Reply #13August 06, 2014, 02:39:13 pm
smutts
  • 720
Could be the turbo coolant return hose, at least that is how it is on the SB & RA engines.
