Author Topic: Hydro head on mech block water leaking  (Read 4099 times)
June 23, 2014, 11:44:40 pm
Kazuki
  • 61
« on: June 23, 2014, 11:44:40 pm »
Hi. I just installed a hydro head on my 1.6  mechanical block but it's leaking water out of the second oil port I plugged I'm using a 1 notch  mech HG  any ideas on how to plug the water jacket ? She's runs great other than this leak I have.
Reply #1June 24, 2014, 05:26:47 am
Re: Hydro head on mech block water leaking
« Reply #1 on: June 24, 2014, 05:26:47 am »
Where the oil passage in the front of the head is needs to be sealed to the outside of the block. I used Teflon joint sealant tape, but you could use a cut out piece from a gasket like the oil fill gasket.
