Author Topic: Only getting 12lbs of boost peek and 10 steady is that normal  (Read 2778 times)
June 19, 2014, 07:28:53 pm
bryanb
  • 25
Sorry for the dumb questions but this is my first turbo diesel. Is 10 - 12 lbs low?  I thought a 1.6td ran more than that stock and I have an upgraded turbo and pump.
Don't be retarded a glow plug is nothing like a spark plug
Reply #1June 19, 2014, 07:41:41 pm
DieselBalz
  • 301
Re: Only getting 12lbs of boost peek and 10 steady is that normal
« Reply #1 on: June 19, 2014, 07:41:41 pm »
With out you giving some specs, shots in the dark is what you are going to get for answers.
Wastegate? MBC? Kind of turbo upgrade?
Reply #2June 19, 2014, 07:51:43 pm
damac
  • 531
« Reply #2 on: June 19, 2014, 07:51:43 pm »
Thats about what my stock 1.6td motors do with the blowoff valve, with t3 and k24 turbos as far as peak, which I think is by design.
I do most of my driving on the freeway.
Steady I don't get 10 unless I'm cruising with hills and/or wind, and it can easily max out.
If I travel on flat land and just chill out going about 74mph, close to 3000 rpms I will get less than 10, maybe closer to 5.
1985 turbo diesel jetta
Reply #3June 19, 2014, 10:42:22 pm
« Reply #3 on: June 19, 2014, 10:42:22 pm »
I think 7-8 was spec on my 84 engine?
Reply #4June 20, 2014, 12:28:56 am
« Reply #4 on: June 20, 2014, 12:28:56 am »
What turbo are you running?
Reply #5June 20, 2014, 01:56:36 pm
Re:
« Reply #5 on: June 20, 2014, 01:56:36 pm »
Sounds like stock numbers for a 1.6td
Reply #6June 20, 2014, 10:44:13 pm
CrazyAndy
  • 739
« Reply #6 on: June 20, 2014, 10:44:13 pm »
Yup, sounds stock.  So you upgraded your pump and turbo?  Can we get some info on what you did?
Did you retain or delete your stock intake-mounted 'blow-off' valve, because that dumps at about the pressure you specified.
