Author Topic: WTB: Mk2 turbodiesel starter  (Read 8230 times)
June 17, 2014, 10:48:16 am
Diesel_Zuk
  • 182
« on: June 17, 2014, 10:48:16 am »
I'm guessing they are probably all the same, that being said, a new one is quite expensive for a college student lol. Anybody have a used one for a good price they can part with? It's for a 1991 ecodiesel, but I doubt that will make a difference. Thanks!
Reply #1June 17, 2014, 03:13:37 pm
Toby
  • 728
Re: WTB: Mk2 turbodiesel starter
« Reply #1 on: June 17, 2014, 03:13:37 pm »
What is wrong with yours. They hardly ever fail. Mostly they need to be lubed and maybe a set of brushes. If its just the Bendix that is super easy.
Reply #2June 17, 2014, 06:14:37 pm
ilikevwdiesel
  • 1202
« Reply #2 on: June 17, 2014, 06:14:37 pm »
pm sent
My Bio
Reply #3June 17, 2014, 06:28:54 pm
Diesel_Zuk
  • 182
« Reply #3 on: June 17, 2014, 06:28:54 pm »
Well I was cranking it trying to get it started, had white smoke, and when I pulled the cold start, it would sputter a little bit, I kept trying, but it just wouldn't start. Then randomly, the cranking speed dropped, now it cranks extremely slow. I already tested a different battery, so I know that isn't the problem. Also, I had both batteries fully charged from the night before.
Reply #4June 17, 2014, 06:50:01 pm
GEE-BEE
  • 1604
« Reply #4 on: June 17, 2014, 06:50:01 pm »
You will get more to the starter if you upgrade the cables #2 for positive
#4 ground
http://www.autohausaz.com/search/product.aspx?sid=equdeh55ynxecdmn42sff455&makeid=800026@VW&modelid=1283352@JETTA GL&year=1991&cid=18@Electrical %26 Vacuum&gid=4152@Starter
107.00 for rebuilt and 2 year warranity..
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #5June 18, 2014, 07:11:38 am
Smoker
  • 255
« Reply #5 on: June 18, 2014, 07:11:38 am »
What he said.  ^
I'd check/upgrade your wiring before you spend cash on a starter.  Even if better wiring doesn't fix it, it's still... well... better.
Reply #6June 20, 2014, 02:38:48 pm
  • 2932
« Reply #6 on: June 20, 2014, 02:38:48 pm »
Yeah, and advance your timing a little.
Reply #7June 27, 2014, 08:15:28 pm
Diesel_Zuk
  • 182
« Reply #7 on: June 27, 2014, 08:15:28 pm »
Son of a beach. I had my local shop rebuild my starter, charged my battery, did timing and everything, and guess what?????!!!!! IT STILL CRANKS SLOW!!!!!! I tried a jumper battery on it too, with very very little improvement. Where do I check next? The engine turns by hand with a ratchet good.
Reply #8June 27, 2014, 08:17:38 pm
Diesel_Zuk
  • 182
« Reply #8 on: June 27, 2014, 08:17:38 pm »
I should add, I didn't change the brass piece, I somehow forgot about it, until now. Is it possible that the brass piece can somehow cause slow cranking? Seems odd to me, but is it possible?
Reply #9June 27, 2014, 08:58:12 pm
Dakotakid
  • 1240
« Reply #9 on: June 27, 2014, 08:58:12 pm »
Actually.....yes.
Reply #10June 28, 2014, 04:14:11 am
« Reply #10 on: June 28, 2014, 04:14:11 am »
From what I have seen this is the #1 reason of failing starters. You HAVE to put a new bushing in every time a new/rebuilt starter goes in. I ruined a rebuilt unit in a week once because I used the old bushing.
Reply #11June 28, 2014, 10:39:11 am
Diesel_Zuk
  • 182
« Reply #11 on: June 28, 2014, 10:39:11 am »
Okey doke. I wonder if my parts house has them in stock, or if I will have to order it?
Reply #12June 28, 2014, 10:41:12 am
ilikevwdiesel
  • 1202
« Reply #12 on: June 28, 2014, 10:41:12 am »
I have 3 good 020 starters in stock.
My Bio
Reply #13June 28, 2014, 02:41:21 pm
Diesel_Zuk
  • 182
« Reply #13 on: June 28, 2014, 02:41:21 pm »
Threw on a mk3 tdi starter I had laying around, spun a little faster, but still not good enough, so I  ordered a bushing. Unfortunately nobody local had it, and the ones that could get it, it would be a couple weeks out, so I ordered from parts place.
Reply #14June 28, 2014, 06:06:42 pm
« Reply #14 on: June 28, 2014, 06:06:42 pm »
The exact same amount of current that flows through the positive cable also flows through the negative cable.  In fact, the current actually flows FROM the negative TO the positive.  Added length of cable can require one cable to be larger than the other (e.g. battery in the trunk) but if they are remotely similar in length and there is benefit to be had from increasing the size, then both should be increased the same amount.
