Author Topic: AAZ vanagon project thread  (Read 25728 times)
Reply #60June 18, 2014, 02:59:51 pm
Renax
  • 90
Re:
« Reply #60 on: June 18, 2014, 02:59:51 pm »
Well, if i where you i'd claim my money back and get another engine. Just basic used stock engine with 200k miles on it is better than what you got...
As vanbcguy says: these engines rarely has bottom end problems, and as you already? ordered a new head a good used engine block would complete the build...
If you want to rebuild the whole bottom end its better to start with one that hasn't been put together by someone you know don't check his work...
Sent from my cheapchinaphone using Tapatalk
-89 Caravelle Coach 1.6TD (too be holset powered) Daily driver
-80 Golf 1.6D
Reply #61June 18, 2014, 04:25:39 pm
zuhandenheit
  • 196
Re: AAZ vanagon project thread
« Reply #61 on: June 18, 2014, 04:25:39 pm »
Well, I placed the head order on hold while I think this through.
I also sent a long message to the seller. It's been almost three years since I bought it - I had other projects, moved, and etc. - so I can't expect much. He's still active around here, though.
I'm really surprised - he was solid to deal with. For instance, he repaid a delivery charge when it was first sent to the wrong local address. He was really helpful and seemed genuinely concerned. Anyway, I'd like to give him the benefit of the doubt, and I hope that there were some honest mistakes on his part.
Rather than buy the head and try to sort the bottom end, I'm thinking about buying Jagerauto's motor:
http://www.vwdiesel.net/forum/index.php?topic=34779.0
I should be able to still use some of my parts (hopefully the IP for instance). I could then take my time trying to make something of my pile of junk motor, or part it out.
Reply #62June 21, 2014, 09:37:02 am
zuhandenheit
  • 196
« Reply #62 on: June 21, 2014, 09:37:02 am »
I'm buying Jagerauto's engine. My old one is completely torn down. I might take the block to a machinist and ask to get the bores checked out. Eventually I'll probably rebuild it.
I don't know what the hell to do with the head and its mismatched cam caps. Maybe I'll try to get it line bored . . .  Or I'll sell it as parts. It's a shame that the whole casting may be scrap just because the seller didn't give me the right caps.
In any case, I've got lots of parts that I'll be listing for sale here soon - manifolds and maybe a turbo, possibly an IP, and etc., etc.,
Reply #63June 22, 2014, 05:29:02 am
Gizmoman
  • 1301
« Reply #63 on: June 22, 2014, 05:29:02 am »
. . .I'm buying Jagerauto's engine.
Probably a good move at this point.
Reply #64July 03, 2014, 01:06:35 pm
zuhandenheit
  • 196
« Reply #64 on: July 03, 2014, 01:06:35 pm »
Hi All,
I've got an update and a question.
I've got Jagerauto's engine, and it looks good. He wasn't sure if he'd replaced the rod bolts when he checked the bearings, so I ordered a new set, along with ARP main studs, and an assortment of other stuff I need to put this together.
Here's my question: My parts arrived today, and I discovered that I'd been sent the wrong rod bolts. I didn't know that the AAZ had two different styles of rod bolts. Unfortunately, this motor has the older bolts, which are different than the TDI bolts (which I was sent). They look like this:
The part number is: 028 105 425 G
I was sent: 028 105 425 C
The dealer first said they're NLA, but did some searching and now says they can get them from Germany, but I might have to wait awhile. Any other ideas?
Thanks!
Reply #65July 03, 2014, 01:08:48 pm
zuhandenheit
  • 196
« Reply #65 on: July 03, 2014, 01:08:48 pm »
Oh, and I found this: http://www.shopdealerparts.com/volkswagen/oe-volkswagen/028105425g
I'm a little skeptical that this site represents an actual inventory, and that I'll get what I order.
Reply #66July 03, 2014, 04:20:03 pm
Gizmoman
  • 1301
« Reply #66 on: July 03, 2014, 04:20:03 pm »
A google search on the part number you provided nets this:
http://www.jimellisvwparts.com/products/Bolt---connecting-rod/5132842/028105425G.html
Here is some info you may find useful as well:
http://bbs.zuwharrie.com/content?topic=123899.5;wap2
As for as which ones are correct though, I'll need to defer to the more experienced.
Reply #67July 04, 2014, 07:50:08 am
zuhandenheit
  • 196
« Reply #67 on: July 04, 2014, 07:50:08 am »
Oh man, thanks! I don't know how I missed that first link - it never appeared in my searches.
After I called Bora Parts, they did eventually find the bolts (in Germany), and ordered a couple sets. The price should be around $4.50 / bolt. Because they've been cool to deal with, I'm going to get the bolts through them. I'm still going to be waiting for a little while, unfortunately.
Reply #68July 04, 2014, 08:01:44 am
zuhandenheit
  • 196
« Reply #68 on: July 04, 2014, 08:01:44 am »
Another thing that I'm wondering about:
I have my ARP main studs now. They say to torque the studs to 60, and to check clearances again after torquing. Is that necessary? Do I plastigauge the main bearing caps?
Thanks again for all the help, ya'll.
Reply #69July 04, 2014, 09:26:46 am
« Reply #69 on: July 04, 2014, 09:26:46 am »
I would torque them to spec then loosen three times and then torque final. Rotate the crank I think is what they are saying to "check clearance"
The purpose of torqueing 3 times is to stress relieve/burnish and get more consistent torque. The first two polish and burnish the bolt threads, the nut surface, and the bearing surface between the nut and cap. By a third torquing, everything’s polished and slicker than after the first. It’s lost the friction that gives the initial reading on the torque wrench. That third, final reading is accurate to within 0.0002 inch of bolt stretch on ARP bolts using ARP moly lube.
Reply #70July 04, 2014, 04:00:24 pm
zuhandenheit
  • 196
« Reply #70 on: July 04, 2014, 04:00:24 pm »
Thanks so much for your detailed explanation! I'll do exactly what you said.
Reply #71July 05, 2014, 06:41:32 pm
zuhandenheit
  • 196
« Reply #71 on: July 05, 2014, 06:41:32 pm »
Okay - Another quick question, which has been asked many times about ARP main studs in general, but apparently not here.
Is it generally not necessary to line hone the crank journal after installing studs? I'm a little nervous about using the studs because of this . . .
Reply #72July 05, 2014, 08:35:45 pm
« Reply #72 on: July 05, 2014, 08:35:45 pm »
It shouldn't be needed. The main caps were installed at the factory and torqued I am sure before machining. Unless you are going to torque it out of spec so far to distort it, the caps will be fine. Whether studs or bolts they are clamping the same piece together. The block locates the caps not the studs or bolts so it should be a non issue.
Reply #73July 08, 2014, 03:25:24 pm
zuhandenheit
  • 196
« Reply #73 on: July 08, 2014, 03:25:24 pm »
Well, the main studs went in without issue, and the crank still spins! The rod bolts have been delayed, so I'm kind of stuck at the moment. I posted some pictures of my progress on my thread at thesamba:
http://www.thesamba.com/vw/forum/viewtopic.php?t=597954&start=40
It's a lot easier to upload pictures there, because the forum software automatically resizes them . . .
Reply #74July 08, 2014, 05:36:47 pm
zuhandenheit
  • 196
« Reply #74 on: July 08, 2014, 05:36:47 pm »
Here's something I'm wondering about:
Should I use my old v-belt setup, or the serp belt? I'll just be running a water pump and alternator . . .
