Author Topic: VR6 / PASSAT CABLE GEAR BOX REBUILD FOR O2A SWAP  (Read 4991 times)
June 10, 2014, 09:05:28 am
GEE-BEE
  • 1604
« on: June 10, 2014, 09:05:28 am »
Here is the info for the parts needed to replace the worn stuff
http://www.diyautoftw.com/content.php?1302-VR6-02A-Shifter-Rebuild-by-violentaesthete
I ceramic coated the bottom cover of the selector box
Powdercoated the housing
Ordered all new parts and shift cables
Parts 425.00
JIM ELLIS VW PARTS .COM
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1June 10, 2014, 09:39:11 am
Re: VR6 / PASSAT CABLE GEAR BOX REBUILD FOR O2A SWAP
« Reply #1 on: June 10, 2014, 09:39:11 am »
Nice...
An even better way to go is to upgrade to the 02J shift tower and the VW Polo shift box in the car.  Then you get a floating ball style shifter in the car and you've got a lot more options for short shift kits, upgraded cable ends, etc etc... Cheaper too...
http://forums.vwvortex.com/showthread.php?5820143-DIY-02A-gt-02J-Shifter-conversation-for-VR6-SLC-Cars
I did this on mine, it shifts BEAUTIFULLY.
