Author Topic: Oil pressure jumping around at higher RPM's - add a windage tray?  (Read 21963 times)
Reply #75July 14, 2014, 12:03:54 pm
Jetmugg
  • 530
Re: Oil pressure jumping around at higher RPM's - add a windage tray?
« Reply #75 on: July 14, 2014, 12:03:54 pm »
As a side note, in the gasser world bosch oil filters are known to cause the oil light to go on. I personally had this happen. They are in the same quality department as FRAM filters nowadays.
Things that make you go....hmmmmmmm.  I wonder if I was suffering from just such a condition.
Steve.
Reply #76July 14, 2014, 01:06:06 pm
« Reply #76 on: July 14, 2014, 01:06:06 pm »
It sounds like maybe your revved it out of gear.  If that's the case, you should test it driving under load with the two significant differences being where the oil sloshes in the pan and the turbo spinning a lot faster.
Reply #77July 14, 2014, 01:34:25 pm
« Reply #77 on: July 14, 2014, 01:34:25 pm »
068115561E is what I use, also some numbers to check would be 068115561BML or 068115561B
I get them from autohaus https://www.autohausaz.com/index.html
Reply #78July 14, 2014, 03:29:52 pm
srgtlord
  • 797
« Reply #78 on: July 14, 2014, 03:29:52 pm »
Here is a bit more reading about the oil filters recommended for gas vw's in case you are wondering :)
http://www.cabby-info.com/engine.htm#Filters
Reply #79July 14, 2014, 06:39:23 pm
Jetmugg
  • 530
« Reply #79 on: July 14, 2014, 06:39:23 pm »
Unfortunately, I don't have any handy locations to run 125 mph for a distance.  I think the at-speed testing is going to have to wait for Bonneville.
Steve.
Reply #80July 14, 2014, 08:02:35 pm
« Reply #80 on: July 14, 2014, 08:02:35 pm »
I'm not talking about going 125.  You can see in your video @ 0:59 that it starts to do it in second gear.  Can you legally drive it and wind out second?  That would tell you a lot more than revving it in neutral with the car standing still.
Reply #81July 15, 2014, 06:47:00 am
Jetmugg
  • 530
« Reply #81 on: July 15, 2014, 06:47:00 am »
It's "plausible" to run out 2nd gear on public roads, but I'd also have to file it under "likely to result in a conversation with John Law".
I'll have to work up some courage for that one.
Steve.
Reply #82July 15, 2014, 04:11:29 pm
« Reply #82 on: July 15, 2014, 04:11:29 pm »
Steve.
If you are otherwise legal remember they work for you, not the other way around. Just keep it in posted speed you will be fine.
Reply #83July 15, 2014, 07:14:58 pm
Jetmugg
  • 530
« Reply #83 on: July 15, 2014, 07:14:58 pm »
The truck is technically legal, (valid plates and insurance), although it has absolutely no lights, and the windows don't roll down, which make even basic hand signals impossible.
Steve.
