Author Topic: any strategies to get a stain off a leatherette seat  (Read 3877 times)
June 03, 2014, 04:16:50 pm
bbob203
  • 1789
« on: June 03, 2014, 04:16:50 pm »
Nice and nasty tar stain on my new 04 b5.5v any tips or tricks?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1June 03, 2014, 07:37:05 pm
Re: any strategies to get a stain off a leatherette seat
« Reply #1 on: June 03, 2014, 07:37:05 pm »
Test it on a small patch, but I have found that I can use the metholated sp? brake cleaner*most all brands normally are like this* on all interior type stuff. As long as it wasn't dyed or painted you will have good results. From what I have read it is basically like the stuff they use to dry clean.
If not that maybe try a citrus based degreaser.
TEST it in a spot with nothing on it to make sure you don't eat your seat. YRMV
Reply #2June 04, 2014, 04:21:39 am
Enslaved_Pickle
  • 45
« Reply #2 on: June 04, 2014, 04:21:39 am »
I would also say brake cleaner, preferably the "non cloronated" type, i use ac delco as it doesn't leave a residue, some of the other brands in a green can i think, leave a residue.
Or try bug and tar remover from a paint supply shop. Both will dry out the spot you use it on so be sure to rehydrate the spot after with the appropriate oils. Stay away from canadian tire armor all and similar products.
I use lexol products on my leathers http://www.lexol.com/
Good luck :)
Mk3 1.9L turbo diesel rat
Reply #3June 04, 2014, 11:34:15 am
« Reply #3 on: June 04, 2014, 11:34:15 am »
We're talking about leatherette (vinyl) not actual leather, right?
From the polyvinyl chloride manufacturers association: "Although PVC swells or dissolves in aromatic hydrocarbons, ketones, and cyclic ethers, PVC is hard to dissolve in other organic solvents."
Do not use brake cleaner (non-chlorinated), it is mostly acetone, which is a ketone; do not use toluene or xylene,those are aromatic (cyclic) hydrocarbons or mixtures containing them (gasoline). Use a non-polar solvent such as "odorless mineral spirits" or kerosene, that shouldn't have aromatic content and test it on an inconspicuous area first.
