Author Topic: wanted: A/C compressor brackets with bolts  (Read 5378 times)
May 22, 2014, 03:16:33 pm
dankcorey22
  • 379
    Cummins!
    • Anything that runs
« on: May 22, 2014, 03:16:33 pm »
I am in search of numbers 3 through 10 and 14 in diagram below. I have found compressor finally! It is going on a 83 jetta TD Code CY
Thanks
Corey
« Last Edit: May 22, 2014, 03:18:31 pm by dankcorey22 »
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #1May 23, 2014, 02:20:24 pm
dankcorey22
  • 379
    Cummins!
Re: wanted: A/C compressor brackets with bolts
« Reply #1 on: May 23, 2014, 02:20:24 pm »
Bump anyone have any of this?
Reply #2May 24, 2014, 07:06:51 pm
« Reply #2 on: May 24, 2014, 07:06:51 pm »
I don't see item #14 in the picture?
Reply #3May 24, 2014, 07:08:24 pm
« Reply #3 on: May 24, 2014, 07:08:24 pm »
I think I do, I will check
Reply #4May 24, 2014, 07:29:26 pm
tdrabbit
  • 15
Re:
« Reply #4 on: May 24, 2014, 07:29:26 pm »
I have all of it, let me sort through my stuff this weekend, shoot me an email [email protected]
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Reply #5May 25, 2014, 06:12:27 pm
dankcorey22
  • 379
    Cummins!
« Reply #5 on: May 25, 2014, 06:12:27 pm »
still need.somebody know they have all the parts?
Reply #6May 25, 2014, 08:21:45 pm
« Reply #6 on: May 25, 2014, 08:21:45 pm »
I am still checking. I just got in from the 2nd day of work shop cleaning. Almost to where I need to be to start looking in the parts box
Reply #7May 26, 2014, 05:36:09 pm
dankcorey22
  • 379
    Cummins!
« Reply #7 on: May 26, 2014, 05:36:09 pm »
Okay thanks!
Reply #8May 27, 2014, 04:09:21 am
« Reply #8 on: May 27, 2014, 04:09:21 am »
I don't know about 5 and 7 but I have the rest. 6 is the pump, but you said you didn't need the pump. What do you want, for sure? I would send you the pump and brackets and the bolts that I have, I also have the alt belt idler pulley attached to it. 100 for all or 65 for the mess minus compressor, if you want them.
Reply #9May 28, 2014, 02:38:36 pm
dankcorey22
  • 379
    Cummins!
« Reply #9 on: May 28, 2014, 02:38:36 pm »
If 5 and 7 is the only items missing ill take it all. Including the compressor. for 100. Is the compressor in good shape and still working condition?
Reply #10May 28, 2014, 02:46:18 pm
« Reply #10 on: May 28, 2014, 02:46:18 pm »
When I took it off years ago it worked, it is still filled with oil, so I will drain it as best I can and send it.
Reply #11May 28, 2014, 02:56:07 pm
dankcorey22
  • 379
    Cummins!
« Reply #11 on: May 28, 2014, 02:56:07 pm »
PM me your paypal. ill send you my address also.
Reply #12June 10, 2014, 08:25:28 pm
« Reply #12 on: June 10, 2014, 08:25:28 pm »
sent  it
