Author Topic: It never seems to end...  (Read 6768 times)
March 21, 2006, 10:21:40 am
A Guy
« on: March 21, 2006, 10:21:40 am »
THis morning on my way into work I couldn't get the car to go completely into 3rd and 5th.  Reverse has been touchy over the last few months.  I tried once to check my manual trans oil but couldn't get the hex cap off.  Is it threaded or just a plug.  I thought it was metal and treaded but seems theres a lip of plastic or something.
BTW 91 Golf 1.6 n/a; 5spd.
Thanks for any and all help.
Out.
Reply #1March 21, 2006, 11:03:39 am
wyldman
  • Authorized Vendor
  • 403
« Reply #1 on: March 21, 2006, 11:03:39 am »
It's a 17mm hex plug.You can use an old wheel bolt and a pair of vise grips in a pinch.If your gonna go in there,might as well change it.Drain plug is the same size.Refill with GM Syncromesh fluid,and overfill it slightly by jacking up the left side of the car.This will make 5th gear last longer.
Are you sure the shift bushings and motor mounts are good ? They will cause all kinds of shifting problems.
Auto Proformance Services - VW Diesel parts and service
(416)565-7282
Reply #2March 21, 2006, 12:43:55 pm
A Guy
« Reply #2 on: March 21, 2006, 12:43:55 pm »
I'm not sure the bushing are good.  I have conciderable side to side play while in gear.  As far aas the engine mounts are concerned I don't know how to check.  All the busshing seem to be going now.  I just did the front and now I have to do the rear control arms and strut bushing as well I have to repack the rear bearings.
Is it a tough job to redo the shift bushings.  Does the tranny have to come out or can I get access from the top in the car where the shifter goes in?
Thanks Wyldman
out.
Greg
Reply #3March 21, 2006, 12:49:55 pm
BlackTieTD
  • 1512
« Reply #3 on: March 21, 2006, 12:49:55 pm »
easy job, you can do it in car no problem. look under the hood at the linkage... its all those plastic bits.
Reply #4March 21, 2006, 01:08:50 pm
A Guy
« Reply #4 on: March 21, 2006, 01:08:50 pm »
you're refering to in the car, under the dust boot at the shifter?
Thanks
Greg
Reply #5March 21, 2006, 01:13:59 pm
BlackTieTD
  • 1512
« Reply #5 on: March 21, 2006, 01:13:59 pm »
oh crap i was thinking rabbit. never done them on a mkII but if you poke around under the hood i'm sure you'll see what you need to change. do you have a bentley manual? nice to have for things like this to see how its all laid out. ekta good too.
Reply #6March 21, 2006, 01:30:49 pm
A Guy
« Reply #6 on: March 21, 2006, 01:30:49 pm »
No.  still no bentley.  I keep looking on Ebay.  Looks like I'll have to pay full pop.  I called a couple of stores in the ottawa area and noone had stock for the year I needed.
So i'm to look under the hood at the shift linkage and I'm looking for plastic bits (5 of them?).  Correct?
What will allow me to realise that they are worn and need to be replaced?
Thanks in advance.
Out.
Reply #7March 21, 2006, 01:34:41 pm
BlackTieTD
  • 1512
« Reply #7 on: March 21, 2006, 01:34:41 pm »
ive seen them on ebay a few times and im not looking for them :P keep trying they come up all the time.
AFAIK the kit to do all the bushings would be $20-40. i'd do it just for ***s. i like to throw parts at a problem until its fixed b/c i'm lazy at troubleshooting. take a damn good guess and replace it if its cheap  :lol:
the way you describe it, it sounds like shifter bushings... R 3 5
if you put it in and out of gear while watching the bushing you might be able to detect play in them. could be missing a bushing altogether, my rabbit was.
Reply #8March 21, 2006, 01:54:24 pm
jantd
  • 38
« Reply #8 on: March 21, 2006, 01:54:24 pm »
Concerning the plug: before turning it loose, give it a few slams of the hammer(with the bolt on it),if you don't it might be hard to loosen,as was mine, and you might screw up the hexagonal and you don't want that...me I bought a 17 mm hexagonal, and I extend it with a tube.Careful not to tighten too much, 2.5 daN.m according to Haynes.
Good luck!
Jan Golf III,322,000 km,AAZ engine
Reply #9March 21, 2006, 02:32:42 pm
A Guy
« Reply #9 on: March 21, 2006, 02:32:42 pm »
thanks all! :D
Tomorrow I have scheduled time away from the store to do some work in the afternoon.  Hopefully everything goes well....
Front bearing, adjust and repack two rear bearings, strut bushings and rear ctrl arm bushings.  Maybe the shift bushing kit if my neighbour doesn't throw me out of the garage first.
Out!
greg
Reply #10March 21, 2006, 03:41:07 pm
Northern RD
  • 167
tools,....
« Reply #10 on: March 21, 2006, 03:41:07 pm »
Reply #11March 22, 2006, 08:49:29 am
chrissev
  • 694
« Reply #11 on: March 22, 2006, 08:49:29 am »
Quote from: "A Guy"
Thanks in advance.
Out.
buy my bentley:  http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=8048301084&rd=1&sspagename=STRK%3AMESE%3AIT&rd=1
looks like it's going cheap.  As far as your tranny goes, it sounds like a linkage problem.  Linkage is directly in front of the steering wheel in the engine bay, under the power brake booster.  Get a linkage rebuild kit and rebuilt it is the best way.  Also need a centering tool to do the shifter, it can get really worn underneath, especially if the plastic cover has holes in it and the salt and dirt has been getting in
Chris
88 Jetta TD....sold for $1000, bought an 06 Cobalt, clearing out the diesel jetta stuff now
Reply #12March 22, 2006, 09:03:18 am
BlackTieTD
  • 1512
« Reply #12 on: March 22, 2006, 09:03:18 am »
Quote from: "chrissev"
hehe, i just went in and drove it up some  :wink:
Reply #13March 22, 2006, 09:47:15 am
A Guy
« Reply #13 on: March 22, 2006, 09:47:15 am »
Thanks chrissev.  You could have just offered it for sale :P
