Author Topic: For sale: Turbo pump parts and V-Band turbo flange  (Read 3556 times)
May 09, 2014, 06:40:56 pm
Powered by Spearco
  • 1203
« on: May 09, 2014, 06:40:56 pm »
I have an 11mm and 12mm turbo pump boost pin and diaphragm.
The 11mm boost pin came from a TD Peugeot. It comes with the Star wheel, lock nut, spring, diaphragm, bump stop and top cover.
Its got the number "19" on the bottom.
$80. Shipped
The 12mm boost pin is from a late model Jetta TD. Comes with the boost pin, spring, diaphragm and bump stop.
Its got the number "56" on the bottom.
$50. Shipped
Turbo charger exhaust flange to V-Band adaptor. Fits MK1 and MK2 turbos. K24, T3. Most likely fit K14, T2. The bolt pattern is T31 on    ATP-turbo web site which is not listed any more. Some of you may know what it is. New, never mounted/used. new was over $50.
$50. Shipped.
I can text you pics.
503-268-2800
Josh
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
