Author Topic: Custom Battery Cables/ Remote Battery Mount VW Caddy  (Read 4951 times)
April 30, 2014, 07:46:27 am
GEE-BEE
  • 1604
« on: April 30, 2014, 07:46:27 am »
I ordered a artec battery cnc mount for the rear of the caddy
http://www.artecindustries.com/Group-34-Optima-Battery-REAR-Mount_p_87.html
Iam doing a 1/0 postive cable to a BMW remote battery jumper near the location of the old battery mount
http://custombatterycables.com/index.htm
Going with a Optima yellow top
This method will allow more room for the interccoling silicone hose assys to the battery location
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1April 30, 2014, 11:29:09 pm
Re: Custom Battery Cables/ Remote Battery Mount VW Caddy
« Reply #1 on: April 30, 2014, 11:29:09 pm »
For less than half of what you would spend, you could make your own cables, I make my own. The same large gauge wire, zinc plated solid copper end lugs and terminals, and heat shrink are all available locally to me and relatively inexpensive... sometimes I scavenge cables from the junkyard, copper prices are so high... BMW and Benz typically have long, large gauge cables and are usually clean. I crimp or swage AND solder the ends on too, with a small torch for a truly indestructible cable.
Reply #2May 01, 2014, 09:04:48 am
GEE-BEE
  • 1604
« Reply #2 on: May 01, 2014, 09:04:48 am »
I will be using 1/o cable with silicone grommets to go thru the cab in two sides..
We all do things different...
Some people make there own intercooler ducts, others have them made professionally
I also do aircraft brakes hoses and landing gear brake hard lines....
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #3May 01, 2014, 05:51:57 pm
Syncroincity
  • 727
« Reply #3 on: May 01, 2014, 05:51:57 pm »
If you can find a Vanagon in a scrapyard, get the starter cable. 14 feet of BIG wire.
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
