Author Topic: UGENTLY NEEDED: Ecodiesel injection lines  (Read 4328 times)
April 27, 2014, 02:19:33 pm
VTPSD
  • 107
« on: April 27, 2014, 02:19:33 pm »
my 91 eco daily driver broke the #2 injections line (second cylinder from passenger side). I need that line or would buy all 4. Paypal ready. Thank you.
-1991 audi 90 quattro with AHU tdi, r520's holset he211
-1990 audi 90 quattro, holset turbo, 11 second quarter mile demon
Reply #1April 27, 2014, 02:23:00 pm
Re: UGENTLY NEEDED: Ecodiesel injection lines
« Reply #1 on: April 27, 2014, 02:23:00 pm »
Before installing the new line, make sure that the bolt at the rear of the pump is tight. It's the #1 cause of broken #2 lines.
Reply #2April 28, 2014, 05:25:04 am
VTPSD
  • 107
« Reply #2 on: April 28, 2014, 05:25:04 am »
good thing to check, thank you!
anyone have these lines?
Reply #3April 28, 2014, 10:24:03 am
TimpanogosSlim
  • 590
    Pretty dumb for a smart guy
« Reply #3 on: April 28, 2014, 10:24:03 am »
if ecodiesel lines are the same as td lines, if nobody has a used one to sell you, mk1autohaus has them:
http://www.mk1autohaus.com/Diesel-Fuel-Injector-Line-Cyl-2--Turbo-Diesel--Hose_p_6578.html
$30 for one line is a bit steep imho.
That guy on ebay who has a TD set that he isn't sure if it's missing line 1 or 2? it's missing line 2. he has two of line 3 iirc.
« Last Edit: April 28, 2014, 10:46:29 am by TimpanogosSlim »
Reply #4April 28, 2014, 10:48:13 am
« Reply #4 on: April 28, 2014, 10:48:13 am »
TD lines are not the same. The delivery valves on the eco are longer.
Reply #5April 28, 2014, 01:03:44 pm
Jaceb-GLI
  • 47
« Reply #5 on: April 28, 2014, 01:03:44 pm »
I have a set from when I upgraded to a TD Pump from the ECO pump. If I fanagle a way to keep the injectors out of the elements I can probably sell them to you.
'91 ECOdiesel
'92 Corrado VR6
'03 Laredo
Reply #6April 29, 2014, 07:42:34 am
VTPSD
  • 107
Reply #7May 01, 2014, 03:36:14 am
Jaceb-GLI
  • 47
« Reply #7 on: May 01, 2014, 03:36:14 am »
Ecodiesel lines are en route to you.
'91 ECOdiesel
'92 Corrado VR6
'03 Laredo
Reply #8May 06, 2014, 06:37:27 am
VTPSD
  • 107
« Reply #8 on: May 06, 2014, 06:37:27 am »
got the lines, thank you!
Just for future reference the bolt at the back of the pump was completely loose!
Good call burn_your_money!
