Author Topic: 1.9 diesel pump problems  (Read 4743 times)
March 20, 2006, 12:38:56 pm
weazlechin
  • 2
« on: March 20, 2006, 12:38:56 pm »
i fitted a golf 1.9 n/a motor in my 1.6 n/a vanagon. i used the 1.9golf  diesel pump but it has 5 sets of wires (2 in each set) and a black box at the rear,these werent on my 1.6 pump, the golf engine is 1996 ish, the vanagon motor is 1982, i dont know what these wires are for and the black box thing. which do i connect to 12v and which do i lose? no fuel is coming through and i am loosing all faith !!
if it aint broke fix it till it is
Reply #1March 21, 2006, 02:42:27 pm
jantd
  • 38
« Reply #1 on: March 21, 2006, 02:42:27 pm »
I am assuming you have a pump of a mechanical 1.9, like AAZ engine.
I remember a link explaining the cut off valve and another to do with timing. it came from member argolf,date:monday jan23 ,2006.the one on top is the cut off valve: this cuts off the fuel to stop your engine ,simply.the other one regulates the timing.purpose:control emissions in cold state.
It's always interesting to make a foto of the particular parts.it's quick and says it all
Anyone knows the 3 other electr connections?
Good luck
