Author Topic: Caddy Rear Window ( slider ) New design  (Read 4779 times)
April 19, 2014, 09:43:01 am
GEE-BEE
  • 1604
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1April 23, 2014, 01:13:04 am
1outof5
Re: Caddy Rear Window ( slider ) New design
« Reply #1 on: April 23, 2014, 01:13:04 am »
GEE-BEE, got one on my truck but have heard that if the seal is not perfect and the install not done properly thae you can have a leaky window.
The thickness of the metal used for the frame on the slider is less than a standard window (glass or plastic)
Just for info
Reply #2April 23, 2014, 06:40:12 am
DogDiesel
  • 210
« Reply #2 on: April 23, 2014, 06:40:12 am »
I have a slider in mine, old type.
No issues with leaks-ever, but unless the latch is locked, it whistles.
You can open it 1/4 inch or lock it and the whistle stops.
But when you open it, even with the side windows raised, (I don't have winged vents), it cools off the cab very well.
Looks like a good source for an upgrade that is well worth the investment.
Wayne
Reply #3April 24, 2014, 06:17:03 pm
GEE-BEE
  • 1604
« Reply #3 on: April 24, 2014, 06:17:03 pm »
I USE MIRACLE BUBBLES AND SOFT NYLON 3/16 ROPE TO INSTALL
NEW SEAL FROM VINTAGE RUBBER, EASY 5 MIN JOB
SORRY FOR THE CAP'S
The new tinted windsheild includes the seal
Giles Pump OHC
MK1 JETTA DASH
Reply #4May 22, 2014, 06:53:31 am
GEE-BEE
  • 1604
« Reply #4 on: May 22, 2014, 06:53:31 am »
I have a extra one for sale in the box 165.00
shipped
Giles Pump OHC
MK1 JETTA DASH
