Author Topic: Injecton pump for JX engine  (Read 5432 times)
April 18, 2014, 07:47:38 am
dave friday
  • 122
« on: April 18, 2014, 07:47:38 am »
Afternoon all, what is the best pump for JX powered van,im after more power to combat the long hills and high winds in Spain.
Ta.
1992 1600 td syncro camper
Reply #1April 18, 2014, 09:15:45 am
Re:
« Reply #1 on: April 18, 2014, 09:15:45 am »
An AAZ pump with a boost pin from a 1.6 or a Rover would be ideal. I know the AAZ was sold in the UK market, not sure about Spain.
Reply #2April 18, 2014, 09:32:13 am
Re: Injecton pump for JX engine
« Reply #2 on: April 18, 2014, 09:32:13 am »
I believe they were widely available throughout the EU. AAZ = 1.9l mechanical engine from early mk3 Jetta for example.
Reply #3April 19, 2014, 05:44:38 am
dave friday
  • 122
« Reply #3 on: April 19, 2014, 05:44:38 am »
Thanks both,the JX is a 1600cc engine [if that makes any difference] picking the right aaz pump is a bit of a mine field as there are so many of them.
What 1600cc pump is the best for power?
Reply #4April 19, 2014, 03:12:43 pm
Re:
« Reply #4 on: April 19, 2014, 03:12:43 pm »
AAZ is a 1900 but the pump is fine for a 1600. It has a much bigger cam plate so it has the most fueling potential.
You want as early an AAZ pump as possible. It should have no more than 2 wiring connections. I think even the earliest ones had a timing solenoid with a single wire on it.
Basically avoid anything with a multi pin plug and you should be fine.
Reply #5April 20, 2014, 12:34:45 pm
dave friday
  • 122
« Reply #5 on: April 20, 2014, 12:34:45 pm »
Thanks,Vanbcguy I have a EGT of 800deg c im not sure if its more fuel that's needed,perhaps a better advance curve?
I'd heard that a gtd pump was better?
I'm after a bit more power .
Reply #6April 20, 2014, 10:10:24 pm
Re:
« Reply #6 on: April 20, 2014, 10:10:24 pm »
More fuel over a shorter period of time, so it doesn't finish injecting too late. You can get this by having more advance (end of injection finishes earlier but you start injecting a bit too soon) or by having a steeper cam plate (more lift over a shorter duration). More fuel over less time will give you what you need - the problem with these engines is getting the fuel in fast enough.
Reply #7April 21, 2014, 12:18:08 am
dave friday
  • 122
« Reply #7 on: April 21, 2014, 12:18:08 am »
Thank you,that explanation is very helpful.
