Author Topic: Noisy door help  (Read 5024 times)
April 08, 2014, 01:26:03 pm
ReubenG
  • 46
Noisy door help
« on: April 08, 2014, 01:26:03 pm »
my pickup drivers side door exterior body panel rattles (usually only at idle speeds). Is there a way to tighten the door / body panel to eliminate noise?
Reply #1April 09, 2014, 10:41:55 am
  • 2932
Re: Noisy door help
« Reply #1 on: April 09, 2014, 10:41:55 am »
Can you actually see the part that's rattling?
 If not it's probably the end of the window roller tube.
 I try to always wrap foam around the end when working on doors.
Reply #2April 10, 2014, 12:26:39 pm
ReubenG
  • 46
Re: Noisy door help
« Reply #2 on: April 10, 2014, 12:26:39 pm »
its the actual door body panel (not any window or other parts) --- I know this because I can stick my hand thru the door vent and stop the rattling by pressing on the door body.
Reply #3April 11, 2014, 05:00:10 am
Re: Noisy door help
« Reply #3 on: April 11, 2014, 05:00:10 am »
I can't recall exactly, but there might be an internal rib  that runs next to the skin that would have a pad to suppress resonance in the skin. If the pad has fallen out of the gap, the skin might rattle against the rib.
Reply #4April 11, 2014, 05:24:52 am
Re: Noisy door help
« Reply #4 on: April 11, 2014, 05:24:52 am »
seam sealer?
Reply #5April 11, 2014, 09:26:42 am
ReubenG
  • 46
Re: Noisy door help
« Reply #5 on: April 11, 2014, 09:26:42 am »
------makes sense...
Reply #6April 21, 2014, 10:56:46 am
ReubenG
  • 46
Re: Noisy door help
« Reply #6 on: April 21, 2014, 10:56:46 am »
Yep, my driver's door is missing the foam pad. I was able to temporarily quiet the vibration by cramming a portion of towel in the space.
Reply #7May 03, 2014, 06:44:33 am
somolovitch3
  • 290
Re: Noisy door help
« Reply #7 on: May 03, 2014, 06:44:33 am »
If you can get a pry device between the two pieces, you can get the nozzle of Expansion Foam in and then pull out the pry device. Let sit for 12 hrs and drive rattle free. 8)
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
