Author Topic: Wanted: AAZ pump, injectors, and pipes.  (Read 3686 times)
April 07, 2014, 12:57:45 pm
AAZTristar
« on: April 07, 2014, 12:57:45 pm »
I have a AAZ long block that was built up using the old JX parts from the engine it replaced.
Would like to buy a AAZ pump, injectors and the pipe set so I can upgrade to the stock configuration.
Shipping will be to Montana.
Obviously I would like the best possible, but I'm willing to look at older pumps for the right price as I'm thinking of having Giles rebuild the pump.
Thank you very much if you can help!
Reply #1April 11, 2014, 01:44:19 am
ein bora
  • 377
Re: Wanted: AAZ pump, injectors, and pipes.
« Reply #1 on: April 11, 2014, 01:44:19 am »
PM sent - I have it all.
If you can't take advice - then you can't be helped!
