Author Topic: Need STANT pressure tester cap part number  (Read 8416 times)
April 07, 2014, 07:57:15 am
DogDiesel
  • 210
« on: April 07, 2014, 07:57:15 am »
Need the part number for the MK1 VW radiator cap and coolant canister test adapters for STANT testers.
I have been removing the top surge tank hose and fitting a tee and reclamping.  Takes too much time.
Does anyone know the part numbers?
Wayne
Reply #1April 17, 2014, 10:31:20 am
DogDiesel
  • 210
Re: Need STANT pressure tester cap part number
« Reply #1 on: April 17, 2014, 10:31:20 am »
How do others pressure test their coolant system and check their surge tank cap?
Wayne
Reply #2April 17, 2014, 01:41:30 pm
« Reply #2 on: April 17, 2014, 01:41:30 pm »
I too have a Stant tester that only  hooks to the big American radiators.
A plumbers  pressure test fitting, a tee, and a scrap of hose has to do it for the rest.
http://www.plumbsource.net/product/1420/0-60-PSI-Air-Test-Gauge-Assembly---Brass-Body.html?meta=GAW&metacpg=1420&gclid=CNmMveOw6L0CFYdlfgodI1oAWw
Reply #3April 19, 2014, 07:05:55 pm
DogDiesel
  • 210
« Reply #3 on: April 19, 2014, 07:05:55 pm »
I use the nipple of the Stant tester, a piece of soft rubber hose, a TEE and splice between the return line and surge tank.
I remember there used to be an adapter for VW MK1s.  THOUGH
Reply #4June 09, 2014, 01:37:50 pm
DogDiesel
  • 210
« Reply #4 on: June 09, 2014, 01:37:50 pm »
12016 Stant Radiator Cap Adapter VW
Thread specifications Metric: 48mm x 3.0
http://www.amazon.com/Stant-12016-Threaded-Radiator-Cooling/dp/B000CKTJXM
When I look this up on Amazon, it said it will not fit my truck, however I have received that message before, and things fit.  Amazon don't dig deep.
I am still looking for an adapter.  Why? because I want one for my kit, and putting the tee in takes too long.
I found this for as low as $14.99 plus shipping. I showed AMAZON because of the picture.
Wayne
Reply #5June 09, 2014, 01:42:48 pm
DogDiesel
  • 210
« Reply #5 on: June 09, 2014, 01:42:48 pm »
To fit the Stant 10225 radiator cap.  HHMMMM.  Looks familiar.
http://www.partsgeek.com/gbproducts/DC/7190-05066124.html?utm_content=DN&utm_term=1975-1984+Volkswagen+Rabbit+Radiator+Cap+Stant+10225+75-84+Volkswagen+Radiator+Cap+1981+1982&fp=pp&gbm=a&utm_source=google&utm_medium=ff&utm_campaign=PartsGeek+Google+Base&gclid=CLD1jLrT7b4CFSgQ7AodUkEApA
Notes: OE Type Radiator Cap -- 20 psi Pressure Rating
1975 Volkswagen Rabbit 1.5L 4 Cyl GAS
• 1976 Volkswagen Rabbit 1.6L 4 Cyl GAS
• 1977 Volkswagen Rabbit 1.6L 4 Cyl GAS
• 1978 Volkswagen Rabbit 1.5L 4 Cyl DIESEL
• 1978 Volkswagen Rabbit 1.5L 4 Cyl GAS
• 1979 Volkswagen Rabbit 1.5L 4 Cyl DIESEL
• 1979 Volkswagen Rabbit 1.5L 4 Cyl GAS
• 1980 Volkswagen Rabbit 1.6L 4 Cyl GAS
• 1980 Volkswagen Rabbit 1.5L 4 Cyl GAS
• 1980 Volkswagen Rabbit 1.5L 4 Cyl DIESEL
1981 Volkswagen Rabbit 1.6L 4 Cyl DIESEL
• 1981 Volkswagen Rabbit 1.7L 4 Cyl GAS
• 1982 Volkswagen Rabbit 1.7L 4 Cyl GAS
• 1982 Volkswagen Rabbit 1.6L 4 Cyl DIESEL
• 1983 Volkswagen Rabbit 1.8L 4 Cyl GAS
• 1983 Volkswagen Rabbit 1.7L 4 Cyl GAS
• 1983 Volkswagen Rabbit 1.6L 4 Cyl DIESEL
• 1984 Volkswagen Rabbit 1.7L 4 Cyl GAS
• 1984 Volkswagen Rabbit 1.6L 4 Cyl DIESEL
• 1984 Volkswagen Rabbit 1.8L 4 Cyl GAS
« Last Edit: June 09, 2014, 01:45:32 pm by DogDiesel »
Reply #6June 09, 2014, 01:52:48 pm
DogDiesel
  • 210
« Reply #6 on: June 09, 2014, 01:52:48 pm »
20 PSI radiator cap.  I always thought MK1 had 7-9 PSI.
Lets do a little math:
If it is a 20 PSI cap, that is 212 F ( + 3 degrees F x 20 = 272 degrees Fahrenheit.  COOL :)
If it is 7 PSI cap (212 +7(x3)=233 Fahrenheit
If it is 9 PSI cap (212 +9(x3)= 239 Fahrenheit
Add in adequate Ethelene Glycol, and there is ALMOST no way a VW overheats, if the cap is good, the hoses are tight, and the head-gasket holds
HENCE - I want a pressure cap to test my system without the engine running.
I was once testing a 16 PSI cap on an old vehicle mine, and I tested it (without cap) to 17-18, stopped to hold, and pooooofph, a hose blew.  I was darn glad it busted in my shop, versus on the road.  All vehicles should break in my shop, where I can get the parts and fix it, and never trailer or tow.
« Last Edit: June 09, 2014, 02:00:09 pm by DogDiesel »
Reply #7June 12, 2014, 01:23:32 pm
Peter
  • 136
« Reply #7 on: June 12, 2014, 01:23:32 pm »
I use a Vanagon cap with the spout on it to hook up the pressure tester hose..such as here (blue)  @ http://www.van-cafe.com/home/van/smartlist_677/reservoir-caps-c677
Reply #8June 13, 2014, 05:26:36 am
DogDiesel
  • 210
« Reply #8 on: June 13, 2014, 05:26:36 am »
I ordered the pressure tester cap 12016 which will allow me to test the tanks and hoses.
Plus I ordered the adapter 12017 which will allow me to test the cap. 8)
For me, this makes sense.  I have had this particular Caddy since 1992, and owned one always since 1987.  I had four of them before this one, selling each as it was fixed and someone offered me a little profit.  Several (4) others since 1992, as projects to be sold. I will get another in time for a project and sell it also.
My home is 1.5 hours from work, and I often drive this little Caddy to Aberdeen MD for satellite site work.  It is the near perfect example of a daily driver.  I run 9 miles over the speed limit on cruise control most always, and on interstate roll with traffic if faster.  Mileage is so good, I don't worry about it anymore.
Bottom line is my coolant system has to be right and tight.  Quite often I pull it in my shop, put it on four jack stands and check everything out.  That's at least quarterly.  It gets 10K mile oil changes, as with all my diesels.
So for me, a pressure tester makes sense.  Understand, by the tracking number, it has arrived.  I will test it this weekend and report factually or sadly it is or is not the right part number.
Reply #9June 23, 2014, 01:08:07 pm
DogDiesel
  • 210
« Reply #9 on: June 23, 2014, 01:08:07 pm »
Part number 12016 cap and 12017 for plastic adapter work perfect. 8)   Ordered them thru Amazon, and they were cheap ;D
Began testing.  My Cap didn't make 20 lbs.  Wasn't consistent.  I will get a new cap.  Thats the good news.  When I hooked the tester up to my radiator surge tank, I was loosing pressure.  ::) Not much, but enough.  I ran out of weekend and had to put it back on the road.  Funny thing, high 90s outside temp and my needle was almost centered.  Guess the oversized 4 pass Schirrocco radiator makes up the difference.   My o' my, what will I do when that thing is sealed tight and I have a perfect cap?
So for me, a pressure tester makes sense.  I will test it this weekend and report factually or sadly it is or is not the right part number.
