General Information
Upgrades (non engine related )
02A swap thoughts?
Topic: 02A swap thoughts? (Read 6271 times)
April 05, 2014, 05:24:36 pm
wolf_walker
02A swap thoughts?
April 05, 2014, 05:24:36 pm »
I'm pretty trans-dumb on anything other than the 020 all my VW junk has had.
Indulge me if this is a simplistic question.
02A's, and swap parts, are cheap enough now I'm actually pondering it.
Not for needing any more robust-ness, but for it being a cheap path to a trans
that isn't 25 years old with 200K plus on it. Professional rebuilds of an 020 are not chap,
and probobly never will be. 02A's are pretty much a dime a dozen now.
Power handling isn't an issue, I'm looking at shift quality.
I drove an 04 Jetta for awhile, shifted like slightly notchy butter, it was pretty great for a VW diesel.
It was worlds better than an 020 in a Rabbit even with new bushings and weighted shift rod.
I'm aware there are less-loose linkage solutions for the 020 and I plan to go that way if I stick with it.
Could I expect later jetta-like shifting from an 02A in my Caddy after the not inconsiderable amount of work
it is to swap?
Mentat Text Two
April 05, 2014, 06:48:10 pm
Re:
April 05, 2014, 06:48:10 pm »
An 02A will shift like an 02A no matter what platform it is in.
The 04 you have experience with will be an 02J - it has a different shifter completely than the 02A. You however can swap the 02J stuff on to the 02A quite easily!
April 07, 2014, 02:46:14 pm
wolf_walker
Re: 02A swap thoughts?
April 07, 2014, 02:46:14 pm »
Shows how much I know on newer trans. Thanks..
After further consideration, I said screw it and ordered USRT's shift linkage kit and short shifter and the mushmaster thingybobber.
Maybe that'll brighten things up.
Mentat Text Two
April 07, 2014, 04:05:00 pm
April 07, 2014, 04:05:00 pm »
I know in the MK2 platform I bought the missing linkz kit and was still not pleased. I was kind of pissed about it as I spent 165.00 for the best of the best kit he had and it still was like a small guys leg in one of my boots. Then I bought the ball socket for the shift tower and it shifts like a brand new car. MKI might have something similar?
Round 2
April 07, 2014, 04:37:23 pm
wolf_walker
Re:
April 07, 2014, 04:37:23 pm »
USRT has a, not cheap, ball socket base the rod passes through. I think it has a bearing in it. It's step two. My wallet hopes it isn't needed.
Sent from my SCH-I545 using Tapatalk
Mentat Text Two
April 07, 2014, 05:21:16 pm
April 07, 2014, 05:21:16 pm »
http://www.4crawler.com/Diesel/ForSale/ShiftLinkage.shtml
Gives a 7% discount to vortex members...I didn't know about that until after I got them...
Round 2
April 30, 2014, 04:12:49 pm
GEE-BEE
Parts
April 30, 2014, 04:12:49 pm »
I did all the parts from him for now, but will build a O2A with the proper mounts for the swap
Iam looking for a freeway flyer
http://techtonicstuning.com/TransRatios.html
3.18 R&P Gear with a .658 final
One of my customers in Bend Oregon is doing the build
http://www.germantransaxle.com/index.php?m=5%26s=747
My O2A shift cables were junk, ordered two new cables and misc shift bushing kit
two new seals for the shift assy 18.00
I will powdercoat before install, the heat sheild was 38.00
Total parts 350.00
Last Edit: May 15, 2014, 01:32:10 pm by GEE-BEE
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
April 30, 2014, 04:19:38 pm
Re:
April 30, 2014, 04:19:38 pm »
I have a CTN out of a Passat in mine. Haven't had a lot of opportunity to drive at speed yet but so far I'm liking it big time.
April 30, 2014, 04:40:31 pm
wolf_walker
Re:
April 30, 2014, 04:40:31 pm »
I had a, 7a it might have been, with a 71, good turbo, less good NA lol.
Mentat Text Two
General Information
02A swap thoughts?
