Author Topic: 020 behind a tdi?  (Read 17921 times)
March 28, 2014, 08:16:24 am
Smoker
  • 255
020 behind a tdi?
« on: March 28, 2014, 08:16:24 am »
I've done some googling, I know guys have successfully run 020's with some power in front of them, and others have grenaded them.  Looking for some real world experience from you guys.  I'm putting a caddy together on the cheap.  I have a complete mk3 donor car with a good trans, and my original plan was to go with the 02a...  however, the more I think about it, the more I'm leaning towards keeping the 020 (at least for now).  The motor will hopefully be running a rover pump, and I'll stick with the stock turbo and nozzles for now.  The idea is to have a cool old shop truck/parts runner that's fun to drive and economical, not a race car.  What do you guys think?
Reply #1March 28, 2014, 08:53:24 am
bbob203
  • 1789
Re: 020 behind a tdi?
« Reply #1 on: March 28, 2014, 08:53:24 am »
Use a mk1 020 they are supposed to be more robust than a mk2 or 3. Put a diff bolt kit into it as well.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #2March 28, 2014, 09:05:33 am
rodpaslow
  • 670
« Reply #2 on: March 28, 2014, 09:05:33 am »
If I were doing it,the 02A is a much better trans to repair, handle more Hp and all the rest.  However, going into your caddy, you need a custom trans mounts (mk3 mount will not work in MK1, will in MK2 or 3), pedals, master and slave cylinders, clutch, starter, Mk3 cable shifter.  You have a parts car for most of the stuff, but are u sure you have an 02A in the MK3.  I just bought a 99 (mind you it canadian) MK3 with a 2.0l and it still has a 020.
It's a big task.  If you have the time it's well worth it
I have do it as well and will be doing it with this car (I have a passat 1Z with 02A) into this 99 MK3 gasser.
I already have a MK3 with a 1.6 and 02A, much nicer shifting, I used a .681 fifth - perfect for highway cruising.  You could probably go lower with a .658  fifth with a TDI.
99' 1.9 1Z Tdi, hybrid pump -1.9 housing & rover internals, 2052 wastegate turbo,.25 hflox nozzles, SDI intake, CTN tranny
96' 1.6 TD Golf, Giles pump, VNT 17, Gas changed to Diesel, Air to Water Int.
Reply #3March 28, 2014, 09:31:05 am
Smoker
  • 255
Re:
« Reply #3 on: March 28, 2014, 09:31:05 am »
Yeah the difference in labor is my only concern. It's just hard for me to justify converting the shifter box, hydro setup, and fabbing mounts for the 02a IF the 020 would hold up.
And I have yet to pop the hood on the donor car, lol, but I've never seen a tdi with an 020 from the factory...
Bbob, I'm leaning more that way all the time. I have a mk1 diesel 5-speed trans.
Sent from my SCH-I545 using Tapatalk
Reply #4March 28, 2014, 09:58:53 am
  • 5104
« Reply #4 on: March 28, 2014, 09:58:53 am »
aba cars were all 020, tdi were 02a.  alot of people on here have used 020, including 8v of fury, i think as long as you drive sensibly you'll be ok, i'd recommend an upgraded clutch tho, i know just from cranking the boost in my 1.6td the clutch would start slipping after some hard driving.
Reply #5March 28, 2014, 10:27:19 am
« Reply #5 on: March 28, 2014, 10:27:19 am »
I'd highly recommend adding a bolt kit to the diff...  Those stupid rivets in the ring gear are the weakest part of the 020.
^^^ That's what happens when the rivets back out over time.  Mine was on a 1.6TD with lots of boost and a big IC.  I don't drive crazy, never was spinning the wheels or anything like that.  It blew apart when I was downshifting coming off a highway one day but I believe it had been in progress for quite some time before that.
Reply #6March 28, 2014, 10:29:35 am
bbob203
  • 1789
« Reply #6 on: March 28, 2014, 10:29:35 am »
Might want to see if someone would trade for a mk1 gas with the 3.67 r&p would be better.. w/ a 1.6 020 and a tdi you will be spinning the tires off a stop.
03 Jetta wagon TDi
Reply #7March 28, 2014, 11:42:21 am
rodpaslow
  • 670
« Reply #7 on: March 28, 2014, 11:42:21 am »
a gasser 3.67 with a .75 gear would be perfect, cruising speed's at about 3000 rpm at 65 mph or so.
Reply #8March 28, 2014, 12:46:11 pm
  • 5104
« Reply #8 on: March 28, 2014, 12:46:11 pm »
also i kind of wonder if the mk3 020s were actually worse, or if the problem had more to do with the mk3 being heavier and having a more powerful engine.
Reply #9March 28, 2014, 12:50:31 pm
Smoker
  • 255
Re:
« Reply #9 on: March 28, 2014, 12:50:31 pm »
Yeah I've seen plenty of busted 020's over the years. Interesting what bbob said about mk1 trannies being stronger than the later ones... I always assumed that they held up better because the cars were lighter.
Reply #10March 28, 2014, 02:08:48 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #10 on: March 28, 2014, 02:08:48 pm »
Took the words out of my mouth. I've also been bitten by this bit of bean counter engineering.
So......... count that another vote for deep sixing the crownwheel rivets.
Sod of a job, but brokevw's website explains it quite well
Reply #11March 28, 2014, 05:12:11 pm
« Reply #11 on: March 28, 2014, 05:12:11 pm »
From what I have gathered the only 020's that were stronger were the 4 speeds. And the only better part of the 020 in the MKi vs the MKii and MKiii was they used a completely different rivet in the MKi that doesn't self machine like the later ones.
If you do a bolt kit it is really only needed in the MKII and MKIII, but if you go to all that work and you are worried about the labor, I would install the 02A. At that point you will have much more time in the 020 breaking it down to the point of the ring gear and you would end up with a better trans.
Reply #12March 28, 2014, 07:06:12 pm
  • 5104
« Reply #12 on: March 28, 2014, 07:06:12 pm »
02a and 02j can get sms too hahaha.  not as common tho, and honestly i have seen more people completely losing gears than having a problem with sms on 020s.  also losing reverse is really really common on 020.
Reply #13March 28, 2014, 07:35:37 pm
smokeinmirrors
  • 38
« Reply #13 on: March 28, 2014, 07:35:37 pm »
  I also went back and forth between the two when I was prepping for my swap. I decided on the 02a because in my case this car is my primary long-term driver and I wanted longer legs and future power upgrade potential. A mkII is much easier to swap cable shift and hydro clutch into than your Caddy though, so labor is definately a bigger factor for you. Cable clutch conversion for the 02a is possible, but I decided against it because the cable routing ends up being funky and you get a very heavy actuation from what I had gathered. If this thing's just going to be a knock around town car, you leave stock size tires, and the transmission is in decent enough nick to start with I think you could get away with the 020 for awhile just to get it on the road.
« Last Edit: March 28, 2014, 07:40:25 pm by smokeinmirrors »
'86 Golf - AHU m-TDI, Garrett GT2052w
Reply #14March 29, 2014, 07:55:23 pm
« Reply #14 on: March 29, 2014, 07:55:23 pm »
mk1 weaker 5th gear then mk2+.... not good idea on tdi... they spin the 5th gear on pinion shaft with 1.6 na when you usee it stupidly.. ive done it... my high hp gasser in 94 broke 5th gear free on the main shaft!!..
get person like me to build you a mk2 020.. and it will last.. no garentee on 5th gear life.. but ive resolved boy racer 3 in a month with 1.. and that 1 was put in multi cars after i built it cause he killed cars then..
the issue is 5th gear needs so much oil.. but say cruizin at 70 and bury foot in 5th.. or towing.. they wipe 5th pretty easy.. why the 02a came up.. but 02a throw diff pins too!!
me and my new boss will have to revisit the 02a i got with holes in it.. to explore a solution better then the one poortex uses.. trust me my mind has ideas.. and new boss can be motivation!!. i likes my new boss and job.. hate being home this weekend..
