Author Topic: Blocking Holes in Heater Box Doors  (Read 2337 times)
March 24, 2014, 06:09:12 pm
ftm1776
  • 149
« on: March 24, 2014, 06:09:12 pm »
1991 Jetta NA, no air.
Not too bad getting heater box out of this model.
Lots of opinions to block all of the holes in the diverter doors in the heater box.
I don't think they are all blocked when new.......????
I am wondering if blocking all of the holes in the metal door that controls the flow to the heater core would cause an overheat condition when closed to any air flow. I guess some air would get by, but ??????????
Thomas, Original and sole owner since new:
1991 Jetta NA 1.6 diesel, Engine Code ME, 5 speed, AWY transmission, Hydraulic Lifters
293,000 miles
LOOKING FOR A GOOD VW DIESEL ENGINE BUILDER ON THE WEST COAST
Reply #1March 24, 2014, 06:27:19 pm
Re: Blocking Holes in Heater Box Doors
« Reply #1 on: March 24, 2014, 06:27:19 pm »
If it is like the A/C ones then yes, every hole is blocked. I used the foil tape for duct and smoke pipe and covered all of mine.
Reply #2March 25, 2014, 09:07:31 am
« Reply #2 on: March 25, 2014, 09:07:31 am »
Every hole should be blocked.
Reply #3March 25, 2014, 02:31:16 pm
« Reply #3 on: March 25, 2014, 02:31:16 pm »
I think they are blocked with like a foam when new, and the foam breaks down over time, which I don't know if that's meant to deliberately let some air pass or if their choice of that material was for noise reasons...
Foil tape seems like a good solution, getting the old material off and the flaps completely clean sounds like the hardest part... I have to do this to my Jetta, not looking forward to it.
