Author Topic: wheels  (Read 4806 times)
March 19, 2006, 11:28:47 am
bryanbryan89x
  • 110
wheels
« on: March 19, 2006, 11:28:47 am »
Does anyone know where i can get some 14''x7'' wheels for my rabbit pick up...I have it lifted it up and now i would like to put some 27"x14'' allterrain tires i have on it.   Wheel adapters are a bit pricey, it would be much easier if i could just find some 4 x100mm wheels.
thanks for any help, Bryan
1981, Rabbit Car, 1.6, N.A.
Reply #1March 19, 2006, 05:10:09 pm
moosiah
  • 106
wheels
« Reply #1 on: March 19, 2006, 05:10:09 pm »
I don't know If this is a help or not , I've got audi 14x 6 on my rabbit from a audi 4000 gt   ( "rollas" some one called them)  I think any thing  stock , wider gets into the 4x110 or 5x110 patterns ...... of course you can Buy all kinds of wheels new if you want to spend buxs.........    :wink:
'81 Frankenbunny: part rabbit, sirroco, golf ,caddy cabrio ,jedda and ! ford teimpo! w a little more Audi and soon some Peogeot too!!!!
Reply #2March 20, 2006, 05:49:46 am
BlackTieTD
  • 1512
wheels
« Reply #2 on: March 20, 2006, 05:49:46 am »
diamond racing steelies might be an option since you are using such a large tire i doubt they would bend or ding (they are meant to be a track rim, not street)... i see you posted a photo in another thread of a diamond wheel so you must know about them. cheap solution.
stockton in california widens steelies.
Reply #3March 20, 2006, 04:33:58 pm
hillfolk'r
  • 1532
wheels
« Reply #3 on: March 20, 2006, 04:33:58 pm »
i used old gti wheels on my lifted truck,,i had sears 195-70,or75,i cant remember-14,,gave lotsa ground clearance,,,,,bet your size sounds close,,,,,i had to trin the lower part of the front fenders,,and smash in the "pinchweld",that extends from the rocker panel,up into the wheelwell,,mine would rub,,nothing some creative thinking witha bfh,and a hacksaw cant fix,,i know if i went much taller,it woulda been a problem
Throttle cables ftw
Reply #4March 20, 2006, 07:01:48 pm
bryanbryan89x
  • 110
wheels
« Reply #4 on: March 20, 2006, 07:01:48 pm »
I have some jetta coils in the front and blocks in the back.  The jetta coils lifted it up quite a ways... and i had rust on my rear fenders so i trimmed them up a inch or so with a die grinder...and i did the front too.  As for the picture of the wheel.  I found it on this website, i dont know where i can get them though...
Reply #5March 21, 2006, 09:06:02 pm
hillfolk'r
  • 1532
wheels
« Reply #5 on: March 21, 2006, 09:06:02 pm »
thats what idid to mine,,a2 front springs,,3 inch blocks in the back,,i did 3 inch longer shackles,,didnt do anything though,,,,oh get a little more lift,,,carefully cut the lower spring perch off,and reweld it up an inch or 2,,i think you can only go about an inch,,,,,,,,watch the right side driveshaft,,it canrub the top of the front control arm mount,especially when on it hard in a right hand corner,,idid make a front suspension limiter,under the control arms,so theywouldnt  rise or top out too much,,have a blast!!
Throttle cables ftw
