Author Topic: Garage Sale! Lots of various things  (Read 5404 times)
March 17, 2014, 05:22:54 pm
« on: March 17, 2014, 05:22:54 pm »
Ok, here is how this will work. I'll only ship items if they value over $15. If you want something and it's only $5, either buy another item or pay $15 for that $5 item. I've tried to price most things far lower than they are worth because I am moving and want this stuff put to use rather than thrown out. Please reference item numbers when asking for things. All pictures can be clicked on for full res.
1) AAZ breather setup $20
2) AHU/1Z intake - could use a cleaning - $20 - SOLD
3) MK1 Non-AC bracket - I am not 100% sure that I have the correct lower adjuster, it may be MK2 - $30
4) Injection lines - pretty sure 1.6TD - FREE
5) MK2 Non-AC alternator bracket - $10 - SOLD
6) 1.6TD oil filter flange - $5 - SOLD
7) 1.6TD fuel injection lines - $15 - SOLD
8) Serpentine crank pulley w/ PS pulley - $5 each (2 sets pictured) - 1 SOLD
9) MK2 non AC alt bracket - $5 - SOLD
10) 1.6TD intake manifold w/ hose - $40 - SOLD
11) 1.6TD valve cover - $5 - SOLD
12) MK2 1.6TD intake boot - $5 - SOLD (I have another)
13) 1.6TD oil feed line - $5 - SOLD
14) AAZ/AHU/1Z lower timing belt cover - $20
15) MK2 dual outlet exhaust manifold - $40
16) Vacuum pump - AAZ and 1.6TD $5 each - 2 1.6 SOLD (3 remaining) 1 AAZ remaining
17) cracked MK2 dual outlet exhaust manifold - $5
18) Various MK3/B4 intercooler pieces $5 - PENDING
19) MK2 Dual outlet downpipe - $40
20) NA injection lines - $5
21) 1.6TD injection lines - $25 - ALL SOLD
22) 1.6TD non AC pulleys - crank, WP and PS - $5
23) 1.6TD non AC pulleys - VWs funny clutched alt pulley setup - $10
24) MK2 manual steering rack u-joint thing (boot not included) - $5 - PENDING
25) Oil pump (should be 36mm) as-is unchecked - $5 - 2 sold (2 remaining)
26) AHU or 1Z TDI pistons - standard bore - set of 4 - $20
27) MK3 TDI fuse box (possibly B4 but I don't think so) $5
28) 1.6TD 1mm oversized pistons - 3 total (plus a demoed one) - $15 - I can get a new 4th piston for about $80
29) MK2 1.6 inner timing belt cover - $5
30) AHU/1Z inner timing belt cover - $5
31) AHU/1Z injector hold down clamps - $5 - SOLD (1 set remaining)
32) Boost hose K03  I believe - $5
33) AHU/1Z coolant glowplug flange - $5
34) Flex pipe - Off a TDI downpipe ~2" ID - $5
35) AAZ oil drain line - Probably off a K03 but might fit others? - $15 - SOLD
36) MK3 or B4 front motor mount supports - Needed for 02A 5 speed conversions I think - $5
37) MK3 TDI cluster - $5 - PENDING
38) AHU/1Z valve cover - $5 - PENDING
39) AHU/1Z intercooler - $10 - SOLD
40) AHU/1Z exhaust manifold w/ coolant heater or EGR cooler- $10
41) 1.6 AC alternator - $5 unknown condition
42) AAZ Injection lines - $15 - PENDING
43) B4 TDI lower Airbox - FREE
44) MK2 PS mirror - remote works, good glass, painted black - $5
45) Turbo diesel heatshields - $5 - 1 SOLD (I have 1 more)
46) ? Ask if you don't see it, I may just have it and it's probably $5
« Last Edit: March 21, 2014, 05:51:38 am by burn_your_money »
Reply #1March 17, 2014, 07:09:09 pm
Re: Garage Sale! Lots of various things
« Reply #1 on: March 17, 2014, 07:09:09 pm »
I'm in for:
10, 11, 12, 13, 21, 39, 45
Reply #2March 17, 2014, 09:32:15 pm
Dakotakid
  • 1240
« Reply #2 on: March 17, 2014, 09:32:15 pm »
I'm in for:  #5 AND #9 AND a #16 1.6 vacuum pump.
Will pm for details.
Reply #3March 18, 2014, 07:12:01 am
DogDiesel
  • 210
« Reply #3 on: March 18, 2014, 07:12:01 am »
I'd like # 35 Turbo return line
Reply #4March 18, 2014, 08:02:14 am
Diesel_Zuk
  • 182
« Reply #4 on: March 18, 2014, 08:02:14 am »
Is 22+23 a pulley/harmonic balancer? I need dual pulleys like that for my mtdi swap, but the ahu balancer won't work, unless I run the vw alternator and serpentine belt.
Reply #5March 18, 2014, 08:35:05 pm
felipe1f
  • 31
« Reply #5 on: March 18, 2014, 08:35:05 pm »
Hi, I am interested in number 2 and number 11, 1z intake manifold and 1.6 td valve cover. how much for shipping to California 90262?
Reply #6March 18, 2014, 09:51:14 pm
Rising
  • 385
Re:
« Reply #6 on: March 18, 2014, 09:51:14 pm »
Grr can't believe I missed this! I'll take the oil feed and return lines, the intercooler pipe scraps, the intercooler, the flex pipe,  the TD valve cover and basically any other turbo goodies you might have ! I can PayPal asap.
Sent from my Nexus 5 using Tapatalk
'84 Rabbit Diesel- 1.6D Stock
Reply #7March 19, 2014, 05:31:49 am
Re:
« Reply #7 on: March 19, 2014, 05:31:49 am »
I think everything you've asked for is pending except the IC pipes. I'll take a picture of the box I haven't opened yet and you can have first crack at that stuff.
Reply #8March 19, 2014, 12:40:42 pm
felipe1f
  • 31
« Reply #8 on: March 19, 2014, 12:40:42 pm »
would the shipping change too much if I buy items # 6 and 31? I am trying to maximize my shipping costs on items I might need later on.
Reply #9March 19, 2014, 03:43:26 pm
« Reply #9 on: March 19, 2014, 03:43:26 pm »
Shipping would not change with those items.
Reply #10March 19, 2014, 07:50:35 pm
Rising
  • 385
Re: Re: Re:
« Reply #10 on: March 19, 2014, 07:50:35 pm »
Cool thanks man! I should just drive up and haul off everything. So many goodies here!
Reply #11March 20, 2014, 04:36:08 am
« Reply #11 on: March 20, 2014, 04:36:08 am »
Indeed you should!
Reply #12March 20, 2014, 03:15:10 pm
felipe1f
  • 31
« Reply #12 on: March 20, 2014, 03:15:10 pm »
I'll send you the $ for all the items we talked about plus the shipping.
Reply #13March 21, 2014, 01:08:30 pm
« Reply #13 on: March 21, 2014, 01:08:30 pm »
Everyone's parts are shipped. If you did not receive a tracking number please IM me.
