learning curve...td fuel lines
Topic: learning curve...td fuel lines (Read 5098 times)
March 17, 2014, 06:31:54 am
vwroadkill
March 17, 2014, 06:31:54 am »
so where was it written that I had to use TD lines. cause I missed that point.. I swapped out my worn out 1.6 for a brand new 1.6td.. block thinking.. {I know! don't think}. after installing rebuilt pump. old lines would work,,, NOT. LDA hits #1 fuel line. and after looking at my kids car.. they are made different.
so here is the question. are the lines a specific length? is the diameter,
I can make the line. I just want to be sure.
can I alter what VW has made... I mean the direction they lay the lines out
just cant believe that this would stop me from running correctly. plus I don't want to break anything
Idea's? inputs? thoughts?
new owner of an 81 caddy diesel yipeeeee..vw gti vr6 and well most of gm's trucks
March 17, 2014, 06:58:27 am
Re: learning curve...td fuel lines
March 17, 2014, 06:58:27 am »
Buy a line of mk1 autohaus on ebay. The TD and NA lines are different on the 1 and 2 IIRC. They are all specific length and take a high pressure *more than brake line* requirement.
Round 2
March 17, 2014, 07:06:54 am
vwroadkill
March 17, 2014, 07:06:54 am »
so 1 and 2 are different. ok... I have stainless and I have two sets of NA fuel lines so I have B-nuts.. then I just have to copy what on my kids car and make mine.... or steal his,,hmmmmm
thanks this will help
March 17, 2014, 07:23:18 am
March 17, 2014, 07:23:18 am »
http://www.ebay.com/itm/220556835942?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649
same seller does single lines.
I wouldn't try to make your own, they need to handle several hundred bar
Round 2
March 17, 2014, 08:09:27 am
March 17, 2014, 08:09:27 am »
I would not mix NA and TD lines.
You can time the pump 1 tooth off and that should give you enough clearance to get the lines one.
Usually if you bend them they will crack within a few hundred or thousand miles.
March 17, 2014, 08:21:24 am
TimpanogosSlim
Pretty dumb for a smart guy
March 17, 2014, 08:21:24 am »
aw crap, I hadn't realized that either.
March 17, 2014, 09:34:59 am
TimpanogosSlim
March 17, 2014, 09:34:59 am »
mk1 autohaus does sell the lines separately. weird thing is if you search by jetta they show you the cylinder 2 TD line and the others NA, search by rabbit and it shows you the cylinder 1 TD line and the others NA.
probably an oversight.
There's a guy selling a used set on ebay but my analysis of his pictures is that he doesn't have the TD version for cylinder 2.
March 17, 2014, 03:09:43 pm
Mark(The Miser)UK
March 17, 2014, 03:09:43 pm »
It would appear that the n/a and TD lines are the same length, at least up until the intercooled stuff '88+ which may be different length.
Then AAZ definitely wrong shape, and possibly different length.
As already stated, shift pump[and pulley] to a more upright position to use n/a #1, and #2 on a TD pump...
Mark-The-Miser-UK
March 17, 2014, 04:03:41 pm
vwroadkill
March 17, 2014, 04:03:41 pm »
well I got couple choices... one make my own..no worries theman aircraft grade lines for a hydro system, ahem you know the kind from a large prop driven 4 engine gray airplane.
two get some used one's... thank you burn..
three order new set... NOT
I did the one tooth off and it works but its cheating, my OCD wont let me do it for long.
thanks for the input
Dan
March 17, 2014, 04:19:21 pm
TimpanogosSlim
March 17, 2014, 04:19:21 pm »
yeah i would rather have the right lines.
I have time to wait for stuff to get here since i still haven't extracted my engine. it was going to be this past weekend but then the constabulary pointed out to me that the Mk5's taxes were in arrears by more than 90 days.
Probably because I was pretty sure it would not pass a thorough emissions inspection. Fixed that instead.
So now i am aiming for this weekend to get the engine out, separated from trans, and onto a stand.
March 25, 2014, 02:41:16 pm
March 25, 2014, 02:41:16 pm »
The problem with making your own, even if you have the ability to manufacture them out of the correct type of material, is that
they need to be of equal length.
This is absolutely critical, or the timing for specific cylinders will be off from the rest. The silly straw bends in the #2 turbo line serve an actual purpose. Of course, if you had a sample or something to work with you might come out with a correct line with the right bends in it but then you might as well just install it, right? They are rare but not unobtainable, at least not yet, fortunately.
Reply #11
March 25, 2014, 05:20:51 pm
Gizmoman
Reply #11 on:
March 25, 2014, 05:20:51 pm »
Not sure if this helps at all but here is a link to my recent purchase for an AAZ 1.9.
http://www.ebay.com/itm/VW-Volkswagen-1-9D-1-9TD-Diesel-1Y-AAZ-Fuel-Injector-Pressure-line-kit-/171098306000?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item27d640f5d0
Fit like a glove.
Yeah, expensive but cheaper than a tow truck from 600 miles out!
