Author Topic: My 95 golf with 86idi motor  (Read 5903 times)
March 07, 2014, 05:47:16 pm
bigbertha72
  • 11
« on: March 07, 2014, 05:47:16 pm »
Here is my ride. Its a 95 golf that had a 2.0 until the timing belt broke and bent valves. So I decided to go with something that gets good mpg and was relatively cheap. I drive a lot for work so I needed mpg over speed these days. This is the first time I have ever done a motor swap for mpg over hp.
Here is what I started with. A 86 idi out of a jetta
Raceware Head Studs
Pulled the head apart
Didn't have the real valve spring compressor. So I made do with a standard pushrod motor one.
Gasket matched the ports and cleaned up the casting some.
My hightech porting station.
Old Motor Pulled out
Diesel sat in. Still need to add a motor mount. Using the 3 stock 2.0 mounts. Haven't decided on where I am going to add the 4th one.
Exhaust built.
Current Projects
1995 Golf with a 1.6idi na (Was my daily before swap, will be once done)
1971 Karmann Ghia 1600 autostick
1972 VW Deluxe Bus (Going watercooled)
1968 Plymouth Satellite with a 383 and 727
1964 Jeep FC170 going on a old f350 frame with a Mercedes om314 diesel and an allison tran
Reply #1March 09, 2014, 08:12:26 am
Re: My 95 golf with 86idi motor
« Reply #1 on: March 09, 2014, 08:12:26 am »
4th mount? You only need the 3 stock ones...
It looks like you know what you are doing. Should be fun. I actually have the same car with the same motor sitting in my yard. It was a 1.8l though.
Reply #2March 09, 2014, 10:14:46 pm
Re:
« Reply #2 on: March 09, 2014, 10:14:46 pm »
My 1.6td mk3 did me great till I eventually killed the transmission. Was plenty of fun to drive too.
Reply #3March 10, 2014, 12:57:22 am
Enslaved_Pickle
  • 45
« Reply #3 on: March 10, 2014, 12:57:22 am »
Yay a white golf with idi :D welcome to the club, i did the same swAp with mine only i went 1.9td, good luck, hope all goes well, i'll be watching :)
Mk3 1.9L turbo diesel rat
