Author Topic: what psi do you roll on?  (Read 2095 times)
March 18, 2006, 07:11:24 pm
sethyboy85
  • 284
« on: March 18, 2006, 07:11:24 pm »
I got a some Falken Ziex ZE-512 195/50/15's and last month I pumped them up to 48psi (max 51psi) I am going to check tire pressure again monday and refill as needed. I noticed about 3-4mpg different from the 32psi the shop put in them.
next tires will be alittle skinnier like 185's, I got 45mpg traveling 70mph 140mi, then doing 80-85mph back, and then 60 miles of my normal driving which usually gets me 38mpg on winterized diesel the other week. Not to bad since the last tank I ran on my car with 175's 13's got me 48mpg on summer diesel and driving no faster than 70mph
so how high do you roll?  :lol:
91 Dodge Spirit R/T 2.2l T3/T4, Big valve head, 3" exh, NPR IC, goal. FS $4000
85 1.6lTD Garrett, NA34X mercedes INJ,2.5" turbo back- Sold
85 TD/91 Eco need to put together to make 1 good car
86 190D Merc with only 392k
96 Volvo 850 Turbo wagon, 1 grainger valve and 250hp/280tq
Reply #1March 18, 2006, 09:11:36 pm
X@V
  • 1002
« Reply #1 on: March 18, 2006, 09:11:36 pm »
A little 8 PSI (stock boost, fuel pump has troubles) winter mode.
Last summer, 16 PSI. 28PSI when the wastegate was stuck.
Reply #2March 19, 2006, 01:05:51 am
maddog007
  • 34
« Reply #2 on: March 19, 2006, 01:05:51 am »
about 38psi all round ,with Pirreli P6000 15"
Reply #3March 19, 2006, 07:02:21 am
HP
  • 225
« Reply #3 on: March 19, 2006, 07:02:21 am »
I do it like the tank cap sticker says: 1.8 - 2.2 bar (27 - 32 psi)
Quote from: "X@V"
Tires pressure.
Reply #4March 19, 2006, 10:27:37 pm
maddog007
  • 34
« Reply #4 on: March 19, 2006, 10:27:37 pm »
Quote from: "HP"
Id go a bit higher unless you are running the same tyres & wheels that came out of the factory with that sticker. :wink:
have a look at the max psi written on the actual tyres & go 1 or 2 psi lower & see how that feels.
Reply #5March 20, 2006, 06:52:30 pm
X@V
  • 1002
« Reply #5 on: March 20, 2006, 06:52:30 pm »
Sorry  :oops:
38 PSI
195-65R14 Toyo Spectrum during summer.
35 PSI during winter (175-70R13)
I'm missing in traction  :twisted:
Reply #6March 21, 2006, 05:01:00 am
HP
  • 225
« Reply #6 on: March 21, 2006, 05:01:00 am »
Quote from: "maddog007"
Quote from: "HP"
I'm running with 185/60R14 and this size is on that sticker.
