Author Topic: 1.6TD manifold to T25 flange (adapter plate)  (Read 13436 times)
February 19, 2014, 07:03:03 am
Alcaid
  • 549
« on: February 19, 2014, 07:03:03 am »
Had a quick look at my workshop yesterday on how much work it is to make an adapter plate so that T25 flanged turbos fit the 1.6TD manifolds, not much actually! Two of the holes align and there is only very little porting needed for a smooth transition over to the T25 inlet used on the Holset HE211W and HE221W turbos. Here is a SKETCH of the adapter plate:
The two top holes (horizontally) align with the 1.6TD manifold: Drill out and use bolts or studs between turbo and manifold through adapter plate
The two middle holes: Tap to M8 and use studs or bolts between these holes and turbo
The two lowest holes: These are the two last holes in the 1.6TD manifold, Countersink these holes and use countersunk screw to attach the adapter plate to the manifold
Use stock 1.6TD gasket between adapter plate and manifold and use a T25 gasket between adapter plate and turbo.
Good luck :)
'10 VW Passat 1.6TDI Highline
Reply #1February 19, 2014, 07:38:01 am
Re: 1.6TD manifold to T25 flange (adapter plate)
« Reply #1 on: February 19, 2014, 07:38:01 am »
thats awesome, could even just thread and use bolts through the manifold on the 2 closer vw holes.
Reply #2February 19, 2014, 05:23:33 pm
Gizmoman
  • 1301
« Reply #2 on: February 19, 2014, 05:23:33 pm »
Very helpful!
Reply #3February 19, 2014, 06:16:17 pm
Gizmoman
  • 1301
« Reply #3 on: February 19, 2014, 06:16:17 pm »
Maybe I received the two DXF files out of scale (one of the exhaust manifold flange and one of the turbo flange) but I don't see any relationships between the two.
I'm missing something somehow
« Last Edit: February 19, 2014, 06:22:52 pm by Gizmoman »
Reply #4February 19, 2014, 08:14:40 pm
  • 2931
« Reply #4 on: February 19, 2014, 08:14:40 pm »
The 1.6  TD exhaust manifold has a trapizoid shape that doesn't match either of your drawings.
Reply #5February 19, 2014, 08:22:56 pm
Gizmoman
  • 1301
« Reply #5 on: February 19, 2014, 08:22:56 pm »
That would explain things.
I'm just gonna wait for the turbo and go from there.
Reply #6February 19, 2014, 10:25:24 pm
Alcaid
  • 549
« Reply #6 on: February 19, 2014, 10:25:24 pm »
You are trying to match up the input and output flange of the HE211W turbine
Here is the 1.6TD downpipe flange pattern:
Reply #7February 19, 2014, 10:52:37 pm
Alcaid
  • 549
« Reply #7 on: February 19, 2014, 10:52:37 pm »
And here is the T25 flange used on the HE211W and HE221W
Reply #8February 20, 2014, 05:40:14 am
Gizmoman
  • 1301
« Reply #8 on: February 20, 2014, 05:40:14 am »
It just "dawned" on me this morning as I was waking up ;D. Someone sat on my thinking cap, luckily, it wasn't on my head at the time.
Thanks Alcaid
Reply #9February 21, 2014, 05:43:44 pm
Reply #10February 21, 2014, 06:19:24 pm
Gizmoman
  • 1301
Reply #11February 21, 2014, 10:28:27 pm
Alcaid
  • 549
« Reply #11 on: February 21, 2014, 10:28:27 pm »
Unfortunately don't think that manifold works in your Vanagon, you need to place the turbo more to the side
Reply #12February 22, 2014, 04:52:18 am
Gizmoman
  • 1301
« Reply #12 on: February 22, 2014, 04:52:18 am »
I'm going to wait till I have the turbo in my hands before I make, buy or do anything else on this. Once I have it mounted properly I'll work out a new intake manifold, the WAIC location and a new intake filter and piping.
