Author Topic: throwing a tdi 1.9 into a corrado.. how difficult?  (Read 9559 times)
March 18, 2006, 03:05:37 pm
ricosuave
  • 244
« on: March 18, 2006, 03:05:37 pm »
and what would be needed?
thanks for any help, i saw the one on tdi club and was interested...
rico
Reply #1March 18, 2006, 03:11:29 pm
  • 1156
    • Malone Tuning Ltd.
Re: throwing a tdi 1.9 into a corrado.. how difficult?
« Reply #1 on: March 18, 2006, 03:11:29 pm »
It's the same as swapping into a MK2 or pretty much any earlier Golf/Jetta/Passat chassis.
Quote from: "ricosuave"
rico
If you had to ask.. buy a complete donor TDI car that was wrecked (without engine or electrical damage). Transfer into the Corrado the TDI longblock + tranny, wiring harness, ECU, gauge cluster, transponder (key), pedal cluster, fuel filter (mounted on front passenger shock tower), etc. The Corrado already has an electric fuel lift pump. Leave that in. After you disconnect the fuel line from the old gas engine, turn the key to "on" position (don't start engine), and let the fuel spray out into a container until the fuel tank is drained.
The fuel tank does not have be totally empty. At most 10% gasoline may be acceptable. Full the tank to the brim with diesel. Of course use only diesel afterwards.
If you plan on running Biodiesel higher than B20 concentration, buy viton or urethane fuel lines (the latter is recommended as it's cheaper and supposedly more abrasion resistant).
Replace the TDI timing belt, fuel filter (cheap), oil filter, glow plugs, maybe lifters if you have time/resources.
http://www.tunezilla.com
93 Eurovan AHU TDI
17 BMW 328d wagon - Sold
09 BMW 335d 3.0L
Reply #2March 18, 2006, 03:15:10 pm
ricosuave
  • 244
« Reply #2 on: March 18, 2006, 03:15:10 pm »
doesnt sound too bad at all
thanks for the info...  might have a cheap lead on both, thats why im thinking!!
rico
Reply #3March 19, 2006, 07:10:23 am
GTD.
  • 183
    • http://tinyurl.com/6yk84
« Reply #3 on: March 19, 2006, 07:10:23 am »
only problem I can for see is the filler neck, diesel nozles are usually thicker than petrol ones so you dont accidentily put derv in a petrol car.
Yo could fit passat clocks as the B2 or is it B3 has the same instruments
[Oo=w=oO]Golf GTD
VW Diesel Mehr Kraft. Weniger Verbrauch, Aus Liebe zum Automobil
Reply #4March 19, 2006, 09:43:16 pm
dubCanuck1
  • 279
    • http://www.canadubs.com
« Reply #4 on: March 19, 2006, 09:43:16 pm »
The MKIII TDI is easier. The MKIV has some problems. Look at the swap in my sig. It's essentially the same as a Corrado. Rear mount issues.
If you want, PM me and we can discuss it further over a few pints.
Reply #5March 21, 2006, 07:58:58 pm
ricosuave
  • 244
« Reply #5 on: March 21, 2006, 07:58:58 pm »
ok, maybe a dumb question, but i need to know - and im serious.
the tdi i had my eye on is now gone.
what if i put in a n/a 1.6 for the time being?  (and i stress time being - to hold me over until i get a line on a tdi)
Reply #6March 21, 2006, 08:53:30 pm
dubCanuck1
  • 279
« Reply #6 on: March 21, 2006, 08:53:30 pm »
Should work, but it's still a bit of work to do. I'm not sure that the Corrado cluster will like much of your diesel stuff and you'll need to run some relays for the glow plugs. Will you be using a diesel tranny or the Corrado one? If you've already got hydraulic clutch in the the rado, keep it. You'll need it for the TDI later on
What's wrong with the Corrado? No engine?
If it were me, I'd just hang on until the right engine came around. There are actually quite a few being sold on TDIClub and VWVortex right now. If it were 6 months from now, I could give you an exact shopping list of things to get, but as of right now, that list would likely be missing a few things.
Reply #7March 25, 2006, 11:56:23 pm
GTD.
  • 183
« Reply #7 on: March 25, 2006, 11:56:23 pm »
Quote from: "dubCanuck1"
as I said use passat b3? TDI cluster, there the same housing
[Oo=w=oO]Golf GTD
Reply #8March 26, 2006, 08:52:35 am
G60ING
  • 170
    Corrado TDI
    • My VW Projects
« Reply #8 on: March 26, 2006, 08:52:35 am »
use a Mk3 or B4 and its a VERY straight forward swap. Use a MK4 and it becomes more involved. I'm using a MK4.
http://forums.vwvortex.com/zerothread?id=2303271
Reply #9April 07, 2006, 10:21:08 am
« Reply #9 on: April 07, 2006, 10:21:08 am »
a very few number of corrados came with factory tdi's they were only sold in canada
Reply #10April 07, 2006, 10:30:26 am
  • 1156
« Reply #10 on: April 07, 2006, 10:30:26 am »
Quote from: "Trev0rbr"
^ Cool, I didn't know that. Got a source?
93 Eurovan AHU TDI
09 BMW 335d 3.0L
Reply #11April 07, 2006, 11:12:17 am
« Reply #11 on: April 07, 2006, 11:12:17 am »
http://www.google.com/search?hl=en&q=corrado+tdi
that's really all i can give you, but the parts guy from my local vw dealer told me about it a car show, he's pretty cool (same guy that helped to confirm my friends td was a td even though it was labeled "16d")  anyway, he told me about it at a car show so i looked it up on google and found a couple source, i think i found some from google images, by reading one of the pages a picture came from.
Reply #12April 07, 2006, 11:23:47 am
« Reply #12 on: April 07, 2006, 11:23:47 am »
but actuall ynow tha ti think about i wonder if this could just be a rumor, because i thought tdis were avaible until 1996 with the passat. and the corrado ended production in 1995.  it could have gotten an early tdi possibly.  but at the same time in 1995 vw was still putting 1.9 idi's in there mk3's.  confusion.  it's almost like the 2 door mk3 jetta rumor.
Reply #13April 07, 2006, 09:06:08 pm
MacGyver
  • 245
« Reply #13 on: April 07, 2006, 09:06:08 pm »
Factory Corrado TDI's in Canada? No.
MK3/B4 diesels in Canada:
1.9L IDI 93-97
1.9L TDI 96-97 Passat
1.9L TDI 97-99 Jetta (1997 could be either TDI or IDI)
No Mk III Golf TDI's unless it's a swap.
Every week someone has a diesel MK 2 or 3 on Auto Trader listed as 'TDI', lotta people think diesel = TDI period.
Reply #14April 11, 2006, 05:42:45 pm
PapaG
  • 7
« Reply #14 on: April 11, 2006, 05:42:45 pm »
Dieselgeek www.dieselgeek.com built one. It belongs to EricS now www.vintagewatercooleds.com
Supposed to be a great driving swap. Eric's wife drives it most of the time.
It is my understanding the Corrado is part A2-A3.
Jim dieselgeek has a shifter business that takes up a lot of his time now.
Richard
Richard "PapaG" Grune
Club Hot Water
Who are you calling a Redneck?
Not while I have my .44 gun
