Author Topic: Are factory Vw rod bearings date-stamped?  (Read 1924 times)
January 28, 2014, 06:37:04 pm
Wayland
  • 364
« on: January 28, 2014, 06:37:04 pm »
I have a 1.6 NA here, unknown mileage, but it has a faded Vw Factory Rebuild sticker on it. I just pulled one of the rod caps to have a look, and noticed the rod bearing is stamped 07-97, and has the Vw logo. I know the old Chevys had the date of mfg stamped on the rod bearings. Does Vw do this too?
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
Reply #1January 29, 2014, 07:52:24 am
Dakotakid
  • 1240
Re: Are factory Vw rod bearings date-stamped?
« Reply #1 on: January 29, 2014, 07:52:24 am »
Apparently, some of the parts used in VW authorized rebuild sites utilized date stamps.
That should be somewhat reassuring to you to a certain degree.
The only "tagged" engines (rebuilds) I have ever seen were from the great white nort. Usually cars out of Minnesota.
« Last Edit: January 29, 2014, 07:56:01 am by Dakotakid »
Reply #2January 29, 2014, 12:04:41 pm
« Reply #2 on: January 29, 2014, 12:04:41 pm »
I've noticed that everything made in Germany comes with some sort of date stamp or code, and I assumed that this was part of some industrial standard used there.
