Hello,
WOndering about how is the best way to
remove the intermediate shaft pulley
I have to replace the water pump...
Thanks, Monst
Actually,
I remembered sort of what I had done
in the past. I placed a deep 3/8 drive
14mm socket in one of the holes. and
then I spun the bolt out..... the 3/8
socket jammed up against the
Intermediate Shaft seal bolt flange
and held the pulley nicely....
So What is the specified Torque
for the Bolt that holds the pulley on..
Thanks, Monst
Select from one of the three:
A) Somewhere between 1 and 1,000 ft.lbs.
B) The same value that it came off with
C) 32 ft. lbs.
Yer choice, dude!
Is retiming the engine faster or easier than pulling the entire pump housing, and separating the pump on the bench?
-Todd
If it isn't a waterpump I personally put together with anti-seize, I take off and replace the whole thing... those little bolts snap easily.
