Author Topic: Looking for an AAZ thermostat cover/water outlet - with pictures  (Read 3829 times)
January 25, 2014, 07:51:12 pm
JimEG
  • 32
Looking for a replacement for the water outlet cover that came off of my AAZ. I would be more than thrilled to find a source for a metal one, but would be happy to even find a plastic(nylon?) one. Also, if a cover with a straight out exit exists, that would work too. I've ordered a couple replacements which I thought were close, or the same - but no luck. Been stumbling around on Rock Auto, Ebay and Google with no luck. Hoping to be enlightened here. Thanks.
The part number on the cover is as follows - 2171 top line, ZA second line, 22S 121 121.
Here are some pic's -
This one
This one
Bottom one in this row. The other ones are different !4 variations used and the new ones I purchased that were wrong.
Bottom one. The top one is one that looked close, but not quite. It is for a 1.8 Golf.
Reply #1January 27, 2014, 08:04:55 am
Spokerider
  • 195
Re: Looking for an AAZ thermostat cover/water outlet - with pictures
« Reply #1 on: January 27, 2014, 08:04:55 am »
I would look at the wreckers....
 I got an aluminum one from an older VW at the wreckers.......can't recall the vintage or model [ it was years ago ], I was getting parts from 1.6's and 1.5's that day, so it would have been from one of those.
Reply #2January 31, 2014, 05:55:27 pm
RockOcean
  • 139
« Reply #2 on: January 31, 2014, 05:55:27 pm »
I use a straight out exit one on my AAZ in a Vanagon. The part number is 038 121 121  My brother could order you one, its not on his website but I know he can get it for $10. Send him an email with the part number if you want one: [email protected]
AAZThermoHaus038121121 by RockOcean.com, on Flickr
Reply #3January 31, 2014, 06:58:04 pm
Syncroincity
  • 727
« Reply #3 on: January 31, 2014, 06:58:04 pm »
What hose are you using with this outlet? Is this a 50-degree install? I've not found a suitable flange for my Syncro, either. I did just buy this one, I hope this solves my fit issues, using a JX-based silicone hose set.
http://www.foreignautosupply.com/parts-accessories/29-billet-thermostat-gooseneck-2lr-tiico-a2-a3-diesel-applications/
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #4January 31, 2014, 07:02:38 pm
Syncroincity
  • 727
« Reply #4 on: January 31, 2014, 07:02:38 pm »
What is the middle flange from, and do you still have it? This might solve my JX hose fit problem... I had to chop off the end and splice on a 90-deg corner.
JC McCavitt
'98 Jetta Wolfie
Reply #5January 31, 2014, 07:20:23 pm
« Reply #5 on: January 31, 2014, 07:20:23 pm »
I've posted this a few places:
Quote from: Andrew A. Libby
$20 and 5 minutes later, you couldn't ask for a better fit...
Reply #6January 31, 2014, 07:24:48 pm
RockOcean
  • 139
« Reply #6 on: January 31, 2014, 07:24:48 pm »
Yes it's a 50 degree install. I am not exactly sure on the measurements but you can see in this picture it has a 90 degree hose which I believe is an 1" 1/4" and that gets reduced to the 1"  steel factory line. Also you can see the reducer coming off the bottom of the expansion tank, and the plug for the oil cooler upgrade. Like I said I am not sure about those diameters and I don't know if these are JX hoses or not.
50degreeAAZHoses by RockOcean.com, on Flickr
