Author Topic: Glow plugs indicator light  (Read 9012 times)
March 17, 2006, 11:29:33 am
A Guy
« on: March 17, 2006, 11:29:33 am »
Why would the indicator light for the g-plugs come on just after the car has started?  It is not as bright as when they are heating - pre starting. It actually flickers a bit and then stays lit.  Loose wire - a bad plug...?  The car starts well.  Any suggesting of where to start are greatly appreciated.
Out.
Greg
Happy St.Patty's Day!!!!!!!!!!!!!!!!!!  :D
Reply #1March 17, 2006, 11:49:18 am
HP
  • 225
« Reply #1 on: March 17, 2006, 11:49:18 am »
With my car happens the just same, but instead of the glow plug LED, it's the battery LED. Stays on for brief seconds after the engine gets started. Then the idle lows down a bit as the light fades!
In my case, I suppose the battery is aiding the engine for its firt revs ( :idea:  ...). I've been told it's normal. Is it?!
In your case, possibly a worn out plug!  :?  Don't know..
Reply #2March 17, 2006, 04:57:50 pm
wyldman
  • 403
« Reply #2 on: March 17, 2006, 04:57:50 pm »
You should not see the glow plug light after it starts.
Either the glow plug relay is bad,or you have a faulty ignition switch.
(416)565-7282
Reply #3March 17, 2006, 05:11:57 pm
stewardc
« Reply #3 on: March 17, 2006, 05:11:57 pm »
What car do you have. On A2 and A3 cars, that is a sign of water in the water separator (there's a sensor in there).
Reply #4March 18, 2006, 09:38:51 am
A Guy
« Reply #4 on: March 18, 2006, 09:38:51 am »
I should have stated that sorry :oops:
I have a 91 Golf w/1.6L N/A
Where is the water separator?
Thanks
Greg
Reply #5March 18, 2006, 09:48:54 am
wyldman
  • 403
« Reply #5 on: March 18, 2006, 09:48:54 am »
There is a water trap under the car,in front of the tank.There also may be one in the bottom of your fuel filter.
(416)565-7282
Reply #6March 18, 2006, 09:59:13 am
stewardc
« Reply #6 on: March 18, 2006, 09:59:13 am »
The water sensor is in the one under the car.
Reply #7March 18, 2006, 04:34:13 pm
hillfolk'r
  • 1532
« Reply #7 on: March 18, 2006, 04:34:13 pm »
if your glow plug light is flashing after startup,drain seperator under car,,if batt light is on,just blip the throttle a little,,its an exitation thing,and its normal,and yes,the idle will drop when the batt lamp goes out ,because now the alternator is now working to  charge up the batt,after firing the car up,glowing,etc,,,,if you have a reallazy one,like i do,,and you bring up the revs  very slowly,when the alt. finally kicks in,you will hear the load change affect the rpms,,,,,,basically its like one of those "1 wire gm alternator",that  the domestic guys use,,let them choke on diesel smog and drain that seperator,even if the light isnt on!!!im thinkin about retrofitting one of those water seperator assemblies on my 79 8)
Throttle cables ftw
Reply #8March 18, 2006, 05:06:41 pm
twopeanuts
  • 15
    • http://www.twopeanuts.com
same subjet different question
« Reply #8 on: March 18, 2006, 05:06:41 pm »
I've got an 82 Rabbit Diesel L - for exactly a week today (and love it).
Anyway - question - the first few days I had the car, whenever starting it cold, the glow plug light would come on solid for a sec or two then flash (with a fairly loud click click click click) that seemed in time with the light flashing - then the light and clickin would stop - and I'd turn it over with the throttle about 50% and it cranks first try even with iced over windows in the morning.
So I was suprised ~Wed morning when I got in and the sequence changed, the light was solid, then flashing, then off but no clicking sounds - silent - so I thought something had failed -  turned it over and it cranked anyway (and on a cold morning).
It stayed silent like that until I went to lunch today - and now it is back to clicking with the glow plug light flashing.
Warm starts - no light - no clicking.
So what is normal?  Silent or Clicky glow plug period?
Thanks!
1982 VW Rabbit Diesel L
-Scott
Reply #9March 18, 2006, 10:41:48 pm
hillfolk'r
  • 1532
« Reply #9 on: March 18, 2006, 10:41:48 pm »
try wigglin the relayaround,,sounds like a bad connection,,it should come on for a while steady,,no blinking stuff,,,or maybe a bad relay,,try slightly twisting or pushing on the relay,,ive had bad connections occur in the fusebox area from dampness/moisture,,ihad one that ihad to pull the relay out slightly for it to workcorrectly,,a cruddy connection where the relayplugged in,,probably one of those 2 things,,sounds like semp sensing side is working,,,,,
Throttle cables ftw
Reply #10March 19, 2006, 07:07:01 am
HP
  • 225
« Reply #10 on: March 19, 2006, 07:07:01 am »
And what about,
Quote from: "HP"
Reply #11March 19, 2006, 09:44:34 am
hillfolk'r
  • 1532
« Reply #11 on: March 19, 2006, 09:44:34 am »
yea thats normal,,,,,,gotta blipthe throttle for lamptogo out,,,alternator may need some revs to "exite",,the speed drop you hear when the lampgoes out is the alternator kicking in to charge,remember,you just glowed,then started,,thats some juice used from the battery,gotta put it back,,,,,totally normal,,,,,
Throttle cables ftw
Reply #12March 19, 2006, 11:06:07 am
HP
  • 225
« Reply #12 on: March 19, 2006, 11:06:07 am »
Just wanted to know the actual reason for that. Thanks.
Reply #13March 20, 2006, 04:13:56 pm
hillfolk'r
  • 1532
« Reply #13 on: March 20, 2006, 04:13:56 pm »
hmmm, i suppose i could break out my book on generators+see the cause on it,,generator/alternator,same thing in my world,zap :D ,basically,,,did you want a "basic electrical" type explination/theory???not to toot horns+stuff,but all the "old" guys in the shop pass all the elec. problems to me,computer diagnostics,or even when a light wont work,heehee,and i do know an electrical engineer that does failure analysis on computer chips too,worked for ibm,theres lotsa knowledge out there waiting to be "picked up!",,
Throttle cables ftw
Reply #14March 21, 2006, 06:21:51 am
Asymtave
« Reply #14 on: March 21, 2006, 06:21:51 am »
I've read that the alternator doesn't "excite" at lower RPM's during starting to ease the load on the starter.  So, when you're cranking, the alternator is just along for the ride putting very little load on the starter.
Then - once RPM's get above a certain point (1200 RPM?) the alternator knows the motor is running, excites and starts putting out current. This is when the "ALT" light goes out.   Makes sense to me.  Clever Germans!
